Old 10-22-2009, 05:12 PM   #1
Adding attic insulation
I want to add insulation over my existing insulation in my attic. The trusses are spaced 22" oc. My current insulation is fiberglass faced bats 22" that is probably 6" to 8" high.
Lowes has a sale on 15" unfaced insulation going on right now (R30). I am planning on just running this perpendicular to the existing insulation. Is this the right type of insulation to run? Should I just buy a wider unfaced insulation? I live in Florida.
My last question is in regards to a mezzanine in the attic. There is insulation under the mezzanine. Should I run the unfaced bats over the mezzanine? Will this cause any condensation problems (plywood acting as second vapor barrier)?
pomelo is offline   Reply With Quote
Old 10-22-2009, 05:45 PM   #2
Xtreme DIY'r
Yes, you can install this perpindicular
You want unfaced to go on top of existing insulation
Wider means less "seems" overall - so slightly better
What do you mean by mezzazine?
Any pics?
Old 10-22-2009, 06:09 PM   #3
Any pics?
It is just a plywood deck on top of the lower chords of the truss. It is just a platform for storage.
Old 10-22-2009, 06:19 PM   #4
If you aren't getting condensation now I wouldn't think adding insulation to the top would cause it. Just run it on over as you said.
I did exactly what you described a few years ago and it made a noticeable difference in how often my A/C and furnace run.
Recently Topped Up Attic with Blown Insulation...Now I have Frost/Condensation earthad1 Building & Construction 81 02-18-2011 01:42 PM
Adding insulation to only a portion of an attic? curls00 Building & Construction 22 10-27-2008 10:41 AM
Adding attic insulation and cutting soffits a DIY job? drh Roofing 15 12-31-2007 08:47 PM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
Is adding insulation in attic cost effective? AllGoNoShow Building & Construction 1 12-05-2006 12:31 PM
