Old 08-31-2009, 05:09 PM   #1
WaldenL's Avatar
Adding add'l support for beam
We're replacing the ceiling and walls in our kitchen. While we've got the walls and ceiling open we've noticed that the header that was added some time ago* to support part of the second floor is supported by a pair of 2x4 on one end. There's an opening in the floor that seems to be where a 4x4 would fit, but there's no 4x4 there. This has supported the 2nd floor and roof load for 25+ years, but since it's open we don't see the harm in adding some "help." Pix will follow this evening.
First, is there any harm in adding help? IOW, can I cause a problem by adding another support?
Second, should I add a 4x4, or a lally column? And do I just size the height and force it in there with a hammer like a well fitted wall stud? Or use a screw lally and adjust the height once it's in there.
Third, should I nail/lag this new member to the old 2x4s? I'm reluctant to touch them as their bearing the weight now.
Thx.
* = Before we bought, and we bought in 95. Likely when the back extension was added, near as we can tell early 80s.
WaldenL is offline   Reply With Quote
Old 08-31-2009, 06:14 PM   #2
Civil Engineer
No, there should be no harm installing an additional support, provided you don't force it in and do some damage in the process. As for me, if I were inclined to add support, I would screw a second 2x4 to the existing 2x4, use construction rated screws (i.e. Simpson structural rated screws), and follow the recommended pattern. Much easier than adding a 4x4.
Old 08-31-2009, 06:23 PM   #3
WaldenL's Avatar
There are currently 2 2x4s next to each other, can't tell how well/if they're attached, I'd imagine (hope) they are. Why do you feel a 2x4 would be easier? Just simpler to get it in there since it's only 2" wide not 4" wide?
How about 2 more 2x4? Any additional benefit? There's room. I'm not looking to add work, but with the walls open spending a couple extra bucks on a 2x4 seems to make sense to me. Perhaps a 2x4 screwed to the existing ones. And then another 2x4 screwed to that one?
As for the screws, something available in a lowes/home depot? And is the recommended pattern on the box? Screws better then nail-gun driven nails?
Old 09-01-2009, 10:00 AM   #4
WaldenL's Avatar
OK, shot them last night, just posting now.
More On This Topic
This is my pressure treated 2x4 used for the framing of your picket fence. Now on this picket fence the frame, the bottom, and the top are pressure treated 2x4's. Now since this is a 24 foot long fence we will need 6 - 8 foot 2x4's. Now when you measure... Read More »
Now we are going to show you how you can attach a new picket fence to a pre-existing picket fence. Now what we have done here is we have taken this pressure treated 2x4 and we have simply nailed it to a pre-existing 2x4 foot pressure treated frame. Now... Read More »
We are standing in a room that used to be a carport when the house was originally built and somewhere along the line one of the owners has turned this in to a living quarters, whether it be a bedroom or a family room or whatever and we are in the process... Read More »
Hi I'm going to show you how to do a combination of a hamstring press and a tricep extension together. The size of your ball is dependent upon your height so if you are anything under 5'4" you are going to get a 55 cm ball, between 5'4" and 5'7" it is a... Read More »
My name is Gail Thompson, owner and operator of Gardens to Grow in Pacific Grove, California. We are here today to instruct you on how to install a picket fence. Of course you will need some concrete mix. Now this is a ready to use concrete mix that you... Read More »
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 09:45 PM
Adding support to "springy" floors-this mom's got to do it herself! LOStouten Building & Construction 10 11-12-2008 09:38 PM
Adding support to subfloor from crawlspace? eqppwqqep Building & Construction 3 04-14-2008 11:59 PM
adding a gas fixture - will the metter support ? amakarevic Plumbing 4 02-29-2008 10:22 AM
Adding Microlam to garage, to support 2 doors and storage??? Shannon Building & Construction 4 12-18-2006 10:51 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
