Adding Additional Floor Joists To Lower Deflection - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-29-2014, 07:07 AM   #1
Rewards Points: 26
Adding additional floor joists to lower deflection
Currently I have a cape cod. 2nd floor joists are 16" OC 2x6 spanning 21.5 with a load bearing wall running up the middle effectively making my spans around 11'. Based on my calculations that puts my deflection at L/182. It will be carpeted so that's fine. My concern is I'm going to be putting drywall for a 1st floor ceiling. And I can only imagine it's going to crack with that much deflection. If I add a second 2x6 to every joist (not just sistered but supported on both ends) my deflection goes to L/364 which is much better for drywall. House is gutted currently so adding full 2x6 not just sistering is actually less work.
Thoughts?
Ignore the terribly framed center load being wall. Not sure what they were thinking. I am reframing it correctly.
03silvers is offline   Reply With Quote
Old 11-29-2014, 07:07 AM   #2
Rewards Points: 26
Picture of ceiling joists
Old 11-29-2014, 08:10 AM   #3
HDS
Rewards Points: 202
Can you go up to 2x8's or 2x10s?
HDS is offline   Reply With Quote
Old 11-29-2014, 08:32 AM   #4
Rewards Points: 236
what is it like walking up there ?
Fix'n it is offline   Reply With Quote
Old 11-29-2014, 08:34 AM   #5
Rewards Points: 648
Isn't that new number good enough for ceramic tiles? For sheetrock, I'd put 2x4 furring strips across the joists, 5/8" sheetrock and have the 4' ends float between the bays.
carpdad is offline   Reply With Quote
Old 11-29-2014, 09:51 AM   #6
Rewards Points: 26
I cannot go up in size without redoing the upstairs floor and also loosing valuable headroom upstairs. I'm only at 7'7" currently.
Old 11-29-2014, 09:53 AM   #7
Rewards Points: 26
Walking up there feels very solid. It was always finished bedrooms. No noticeable bounce. The existing 2x6 are from 1929 but are not rough cut dimensions.
I'm not sure I follow what your saying. I do not want to lose headroom downstairs by adding additional 2x4s
Old 11-29-2014, 11:10 AM   #8
MarginallyQualified
Rewards Points: 2,464
Add steel "sisters" to the 2x6's and maybe some blocking.
1/8" or even 12ga sheet cut to size and through bolted should be adequate.
Using a layer of 3/4" plywood -with the steel sandwiched- is even better.
Old 11-29-2014, 11:17 AM   #9
Rewards Points: 26
I appreciate all the other suggestions. But time and money are obviously a factor. I'm really just wanting to know opinions on adding additional 2x6 joists supported on both ends just as the existing ones are
Old 11-29-2014, 11:47 AM   #10
joed's Avatar
Rewards Points: 12,446
Blocking would help as it will keep them from twisting and lock them together with the ones beside them.
The Following User Says Thank You to joed For This Useful Post:
03silvers (11-29-2014)
Old 11-29-2014, 03:10 PM   #11
Pro
JetSwet's Avatar
Rewards Points: 502
What?... Unless your joists are bowing when some one is upstairs walking around its silly too go nuts thinking about. Sheetrock would be fine
JetSwet is offline   Reply With Quote
Old 11-29-2014, 05:27 PM   #12
HDS
Rewards Points: 202
You also have to figure in weight of furniture and such, not just a person walking on the floor. Sistering in the 2x6s would also ensure you can add tile at a later date.
The Following User Says Thank You to HDS For This Useful Post:
Old 11-29-2014, 06:06 PM   #13
Pro
JetSwet's Avatar
Rewards Points: 502
There is a load barring wall, from the pics right in the center of the room which would need to be for a 2x6 joist run like this
Old 11-29-2014, 06:30 PM   #14
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,524
Silver....
My thoughts are that your idea is smart... given your circumstances. L360 is standard max.... you're gutted and now is the time to do it... should cover you in the future for any changes....
(I would probably add some blocking also... ties your floor performance all together)
Best
MTN REMODEL LLC is offline   Reply With Quote
The Following 2 Users Say Thank You to MTN REMODEL LLC For This Useful Post:
03silvers (11-29-2014), oh'mike (11-29-2014)
Old 11-29-2014, 08:28 PM   #15
Rewards Points: 469
Im in the process of remodeling a house that is exactly like what you have, I have doubled up the floor joist in the whole house and there is no noticable deflection and it passes code. Only difference is my house was built in 1936 and the 2x6 were ceiling joist with storage above that was converted into living area and it destroyed the plaster
Jnaas2 is offline   Reply With Quote
The Following User Says Thank You to Jnaas2 For This Useful Post:
Choosing additional heat in the lower level mom929 HVAC 3 05-17-2013 01:48 PM
strengthening floor joist jpaz Building & Construction 26 12-08-2012 04:14 AM
Adding a Fourth, Lower Speed to Fan ElleNavorski HVAC 0 05-27-2012 01:19 PM
Adding a Additional Room christopher_45 Building & Construction 1 06-29-2007 04:23 AM
Adding an additional sink in Bathroom tke402 Plumbing 1 04-26-2007 09:14 PM
