Adding A 2nd Story To An Existing Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-17-2009, 09:37 PM   #1
adding a 2nd story to an existing garage
I have a
2 car garage on a floating slab
2x4 construction
the roof / trusses is a gable roof... not real steep..
the garage is a standard looking garage that you see all over
My question is, can I make this a 2 story so I can have storage or living quarters on the top level..
2nd question is can I make this 2x4 contruction into a 2x6 contruction?
and where can I get some information and plans on how to do it?
Thanks.. I am a novice carpenter!
chrissygarden is offline   Reply With Quote
Old 08-17-2009, 09:46 PM   #2
Can it be done - Yes
Are you planning on doing it?
You will not find exact plans/instructions, you would need to either draw them up yourself or hire someone
Is it 1 garage door - big, or two?
Why do you want to change the 2x4 garage into 2x6?
Or do you want to just have 2x6 on the 2nd floor - more insulation?
Rip the roof off
Put a new floor across
Build new walls
Build roof
Finish as needed
Old 08-17-2009, 10:26 PM   #3
There is 2 garage doors...
I wanted it 2x6 construction to add insulation and I thought I may need more support for the 2nd level..
I live in Wisconsin, so I was not sure if the floating slab could take all the weight of the 2 story addition.
And can I raise the height of the walls on the first story?
Thanks for your advice...
Old 08-18-2009, 10:22 AM   #4
So there isn't a foundation under the garge walls?
That will be a problem
Old 08-18-2009, 10:11 PM   #5
no foundation
just a floating slab...
but it is in real nice shape, the concrete is about 5-6 inches think..
So what do you think>>
Old 08-18-2009, 10:21 PM   #6
If its just a slab 5-6" thick I doubt it will carry the weight of a 2nd floor
Is this attached to the house?
My (new) attached garage w/2nd floor & walk up attic I had to put a footer & foundation in down to ~4'
Old 08-18-2009, 10:28 PM   #7
the garage is free standing...
So do I have any other options to get this garage a 2 story besides tearing it down and starting over with a concrete footings???
Old 08-18-2009, 10:32 PM   #8
That option would be beyond me - you need someone in concrete
Possible you could dig out & have concrete poured under edge of slab
Or jack up garage, cut edges of sab & have foundation poured
But beyond my experience
Old 08-18-2009, 10:54 PM   #9
Registered User
Rewards Points: 5,514
I suggest you contact your local Building Department, and ask them.
The minimum code accepted is 8" wide concrete wall on a 12" wide x 7" deep concrete footing to support a two story building.
You may get by with an engineered footing down at your frost depth, pinned and poured under the slab, but again, it's a local thing.
Ask them if they accept this, a lot easier:
http://www.oikos.com/esb/43/foundations.html
Be safe, G
wiring from existing panel to new garage al99m Electrical 8 07-29-2009 08:42 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
adding heat ducts to existing plenum milcurt HVAC 4 01-13-2009 07:52 PM
Questions on Building apartment On top of existing detached garage nsxman2001 Building & Construction 4 12-16-2008 04:36 PM
Adding radiant heat to existing slab Seabass HVAC 9 04-27-2007 04:10 PM
