Addinf Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-23-2010, 10:53 AM   #1
Addinf Insulation
If I am adding more cellulose insulation on top of my existing cellulose installation, do I need to fluff what I have there know? I have been adding recessed lighting and have been crawling around compacting areas
howard.wheaton is offline   Reply With Quote
Old 11-24-2010, 01:22 AM   #2
Rewards Points: 1,092
I really don't know if you can compact cellulose with a little hog stomping, but if it makes you feel better, stir it a tad. I'd be surprised if you can compress it beyond dense-pack density, but really don't know. So why am I replying? The lights caught my attention. Since I guess they are already there, take extra time to air seal them, and make sure you have the cellulose as far from them as the manufacturer says to. Make sure you don't exceed the weight limit (with the cellulose) per square foot for whatever OC your trusses are.
Old 11-24-2010, 07:13 AM   #3
Thanks. The lights are IC rated so the insulation is fine over them.
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
How hard to install insulation yourself? techprincesse Building & Construction 26 10-17-2009 09:57 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
