Add Support Posts To Existing Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-14-2012, 03:25 AM   #1
add support posts to existing deck
My deck is 30 inches above ground. How do I additional posts
hendan is offline   Reply With Quote
Old 05-14-2012, 06:18 AM   #2
Not easily. Support posts require a concrete footer that goes below the local frost line. Not easy to dig with only 30" of space. Removing some of the deck boards might help.
I am assuming that deck was built without a permit, which would have required drawings showing support posts?? If the support was not adequate, it would have been caught then. What else is lacking in your design?? Proper fastener spacing on the ledger board??
Old 05-14-2012, 08:41 AM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
First; ad an additional post to your original post and put some information in it, becuae I don't understand what you want.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Replacing existing load bearing deck posts Tubachin Building & Construction 2 09-07-2010 04:33 PM
Guidance needed for deck support posts Mike Loyd Building & Construction 4 08-23-2009 07:03 PM
8' x 12' deck how - many support posts needed shuanrit Landscaping & Lawn Care 5 07-09-2009 09:57 PM
warped deck rail posts cakem Carpentry 1 05-09-2009 08:24 AM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 04:24 PM
