Add A Second Floor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-26-2012, 06:05 PM   #1
add a second floor
if you already have a second floor,i.e a split level house, was the house originally designed for a second floor over the first floor of the house?
saints is offline   Reply With Quote
Old 01-26-2012, 06:39 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by saints View Post
If you already have a second floor, i.e a split level house, was the house originally designed for a second floor over the first floor of the house?
No. Or at least not damned likely.
If you can get up there... see if you have actual joists or roof trusses.
And if joists... the size and centers and span (oh my!).
Maybe you'll be the lucky one.
If your next Q is whether you could add a second floor anyway...
Sure. All it takes is a big pile of lumber and another pig pile of cash.
First Floor Laundry Room Floor Drain install? hammerlane Plumbing 9 10-21-2011 09:12 AM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 07:45 AM
