Add A Raised Edge To A Driveway - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-19-2010, 03:24 PM   #1
Add a raised edge to a driveway
I'd like to have a permanent raised edge put on the driveway to keep flowing rainwater off of the grass.
The edge would be 2" high and 2" wide, and the length of about 8 feet of the driveway (and also making a right-angle turn to go onto about 4 feet of the house's sidewalk).
The driveway material (and sidewalk) is that tan pebble stone aggregate type of driveway. How could this edge be added?
Currently I just have black rubber/plastic edging.
Thanks,
Nashville, TN
joshoc is offline   Reply With Quote
Old 09-19-2010, 04:13 PM   #2
Old School
Willie T's Avatar
Yeah, that water will kill your grass.
Willie T
Old 09-19-2010, 11:28 PM   #3
Rewards Points: 502
bring in a load of topsoil.
forresth is offline   Reply With Quote
Old 09-20-2010, 08:40 AM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
make forms and pour concrete
or
use landscape ties
or
use pavers or brick
or
mound mulch & plant something
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 09-20-2010, 11:01 AM   #5
For 2" wide, maybe you could rip and rout that dimension from PVC decking board and glue/tapcon it along the edge. That wouldn't be 2-inches tall though--closer to 3/4" tall but thsould be enough to divert water, assuming the driveway itself isn't somehow below the grade of the surrounding grass, or if you're in some sort flood-prone area. Just an idea.
You can also use landscape pavers turned on edge and partially buried so only 2 inches shows above grade.
tom_matthews is offline   Reply With Quote
Old 09-21-2010, 05:43 AM   #6
If someone came and made forms and poured concrete, isn't there some sort of adhesive that has to be used to get the new concrete to adhere better to the existing concrete?
Should concrete driveway slab be thinner on the edge by the forms? Studly Building & Construction 6 09-14-2009 09:24 AM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
6'x10'x6" thk concrete slab to be raised on one edge by 2" Yoyizit Building & Construction 8 05-24-2009 10:54 PM
How do I finish the edge ot my Raised Patio rabih_00 Landscaping & Lawn Care 4 09-08-2008 02:10 PM
Shingle Installation with F5S Standard Drip Edge ShortEdged Roofing/Siding 32 02-15-2008 02:10 PM
