Old 11-01-2009, 01:25 PM   #1
Default Add insulation to solid timber roof
Central North Carolina....
I have an upstairs addition added over a sunken carport in the mid 70s that transformed a ranch into a split level. The carport was enclosed later (I think) to make a finished basement that is just barely below grade on the uphill end.
There is no insulation in the roof and no attic space.
The roof deck is 2 layers of 2x6 boards over exposed solid 5"x10" rafters.
The beam rafters are on 4 foot centers. There is no ridge beam. There are no collar ties so the roof has some sway away from the gables, but that doesn't seem to have changed in the 5 years we have been here. Pitch is fairly low, around 4/12. No leaks but shingles are getting old. When you are inside and look up, the ceiling is the roof deck. It is a bit hard to cool in the summertime .
We would like to change to metal roofing if we do a tear off, but I am worried that the metal roof seams would make the sway look a lot worse if we don't correct it. I have no idea if sway is always bad or if it HAS to be corrected. It does appear to be stable now. If metal would just compound the problems of insulating a structure with no air spaces we could go with shingles again. We don't want to change the appearance on the inside, but I may be able to talk the wife in to accepting a few collar ties.
The obvious solution to me is to tear off the top layer of 2x6s then add 2" solid foam isulation topped by plywood or ply and nailers for the metal roof.
The second solution is tear off all the 2x6s and use them to just build a new house but we would have a bunch of 2x6s left over that we would heave to deal with ... that is a thick pile of wood up there.
thanks,
Justin
justinNC is offline   Reply With Quote
Old 11-01-2009, 01:52 PM   #2
Isn't that extra layer of wood giving you some insulating value, that may be why they doubled it. I would check and see if the R value of the 2x's is close to equal to the R value of the foam before I tore anything off. Wood is a good insulator. The ceilings are gorgeous, I have a log home and have these as well, they are very expensive to put in now. A few collar ties made and stained to match existing ceiling would probably still look o.k. , as many of the log homes have some forms of collar ties which match the beams. You may want to look at some log home interior pictures to get some ideas. Also they use some sort of foam insulation under the metal on metal roofs, I think. You may research this as well.
joan518 is offline   Reply With Quote
Old 11-01-2009, 02:16 PM   #3
Home Slave
Lazy_Jake's Avatar
Is your only concern keeping the house cool in the summer time? I'm thinking that if you need to replace the roofing soon anyway, you might want to think about getting a light colored architectural shingle. The lighter color will help drastically if your existing shingle is dark. Me personally, I would stay away from metal roofs. I have seen a couple that were hit by a hail storm and they look awful now.
My $.02.
Lazy_Jake is offline   Reply With Quote
More On This Topic
On behalf of expert village, my name is Gregg Tauriello. I'm from suite 16 studio. I'm here to talk to you about soundproofing your recording studio. On this building I have T-111 siding on the outside, which is a standard cardboard siding that you will... Read More »
Tin roofs have been around for centuries. The tin roof at Monticello, Jefferson's home, is still in good condition, despite being the one originally placed on the house when it was first built in the 1800s. Occasionally, it is necessary to pop one or... Read More »
If you have the need to store large amounts of ice, building an ice house is a project for you. Popular many years ago, now most freezers now come equipped with ice makers to produce a sufficient amount of ice for a family, but are not designed to handle... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will checking the roof for loose or missing shingles. To check for any loose or missing shingle, you just want to take a close look at your roof. If there are any areas that might look... Read More »
Roofs last along time, so it's entirely possible you have owned a home without ever having to pick replacement shingles. Or, it has been such a long time there are new products on the market from which to choose. Pick replacement roof shingles by... Read More »
Am I getting ripped off?!--Improper Ventilation of a metal roof? mico7716 Roofing 0 06-18-2009 02:39 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 06:08 PM
Flat Roof Construction- insulation EricC Roofing 15 12-02-2007 10:49 PM
how can I support my timber roof? cjwcarpentry Roofing 2 03-04-2007 03:52 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
