Old 10-28-2007, 07:49 PM   #1
Extreme DIY'r Adk's, NY
ADA codes questions / commercial
Can someone give a brief but accurate overview of when a commercial property needs an ADA restroom? NY state. Is it type of use, square footage, locale, etc?
TIA
crecore is offline   Reply With Quote
Old 10-29-2007, 08:10 AM   #2
General Contractor
joasis's Avatar
Some local codes can go way beyond the federal guidelines, but you can find the information from the ADA website....nearly every commercial project we look at will always be ADA compliant, since it isn't hard to make it work, then no problems.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Adding a subpanel to a sub-panel and other questions CardinalPilot Electrical 14 03-30-2011 03:23 PM
Aluminum-wired house, questions LMH Electrical 2 05-24-2009 04:06 AM
Commercial Ballast for Residential ???? lanyard_loop Electrical 4 11-11-2008 02:52 PM
tiling questions - in middle of install mwill Flooring 8 12-11-2007 06:06 PM
some questions on masonry/cement/concrete (general q's) joeyboy Building & Construction 20 06-25-2007 09:53 PM
