Old 01-26-2011, 04:41 PM   #46
Framing Contractor
Actual room sizes not as large as the Blueprint measurements!
[QUOTE=AgentW;578494][quote=ubenhad4;578413]
Originally Posted by AgentW View Post
Well, if you look at the plans and see that the first joist from the back of the house is not 16" O.C., and the front of the house is, then it's pretty easy to figure out.
Where I'm from they don't mark the joists on the plans, so what you said would never happen. The just mark the direction of the joists never the lines showing joists.
The point of my story was really just that I've dealt with far too many contractors who do things 'their way' without consideration of how their way affects the next contractor to come in.
Then your dealing with the wrong contractors or the cheapest ones. I frame, so therefore I have to be concerned for the next guy. It doesn't make any sense not to be. We all have to look out for each other when building. If there are any problems then all the subs should meet and solve them BEFORE they finish their job so that the next guy doesn't have problems.. Communication!!
Joe Carola
Joe Carola is offline   Reply With Quote
The Following 2 Users Say Thank You to Joe Carola For This Useful Post:
AndyGump (01-26-2011), tcleve4911 (01-26-2011)
Old 01-26-2011, 08:57 PM   #47
your so right. i have talked to my builder and that is what he told me...
so i guess i have to take the bitter with the sweet!
thanks for the info.
CheriAlli is offline   Reply With Quote
Old 01-26-2011, 10:54 PM   #48
KemoSabe
loneframer's Avatar
This is absolutely true. Though, a lot of times, I've found this is because something was done incorrectly before that point so, to account for that, a deviation needs to be made.
The only one who knows for sure is the framer, but I can tell you, plans are never perfect.
Of course it does. If joists are placed at 16" or 24" O.C. from back to front, rather than front to back, and that front to back dimension is not evenly divisible by those O.C. placements, the joists will end up in different places than originally designed.
I've rarely had plans that specified a joist layout, unless it was designed by an I joist company and they rarely, if ever in my experience, make accomadations for plumbing.
That means, if a builder and a plumber (in this case, me) are given the designs and I design my drainage and venting based upon the joist layout as designed, but the builder decides to do his own things for no reason other than "that's how he does it", without taking into consideration how those changes will force others to rework their designs, then that's a problem. It caused a joist in the WC to fall directly beneath the drawn toilet, forcing me to move the toilet much further off the wall than I wanted. I also had to rework the drainage to account for this change.
I always take considerations for drainwork and wet walls, which, again, are rarely if ever, specified on a set of plans.
A good framer will walk away knowing that you, the plumber, will breeze through the house without joists or studs in the way. That's how it's done correctly. Now find a builder who is willing to pay for a good framer who takes the time to do his homework and you may find me on one of those jobs. Joist layout should not be left to chance. The framer is responsible for laying out for you guys. Trust me, just because it's on a drawing, doesn't mean it works.
It didn't mean it couldn't be done. It just meant that I had to do more work because the builder "does what he does", regardless of how his work affects the next person who comes in and has to work with it. If the joists are drawn front to back, then that's the way they should be built. Doing it the other way is either a sign of apathy, or poor attention to detail.
Or the lack of a drawing to begin with. Again, it doesn't matter where you pull layout from. Joists can and should be moved off of layout to allow for plumbing. I've been doing it for 25 years. It's not that big of a deal.
Now if you're talking about a cheap job, where there's not 1 extra joist to put in to split a layout, maybe it matters, but should still be double checked by the framer, not left to trust in the designer.
loneframer is offline   Reply With Quote
The Following User Says Thank You to loneframer For This Useful Post:
ubenhad4 (01-26-2011)
Room Air Purifier - which is best? nhart Appliances 16 12-07-2012 07:00 AM
Cold Room mikelbeck HVAC 14 01-16-2009 09:21 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Heat pump in non insulated nor heated room robdville HVAC 3 01-21-2008 03:51 PM
Crazy large noise/vibration when turning on the shower in one of the bath room! Help! KUIPORNG Plumbing 6 05-25-2007 05:55 PM
