Acrylic Bath Tub Install - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-16-2013, 01:03 PM   #16
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I never put holes in a tiling flange. It's there as a backup to the caulking that goes between the tile and the tub. If that caulking fails and you have holes all through the tiling flange, the water isn't going to stay inside of the tub.
Set tub in mortar and use screws just above the flange with large fender washers to keep the tub from moving horizontally.
Journeyman Plumber
Old 03-16-2013, 01:03 PM   #17
having a shower has nothing to do with fastening the tub to the wall. it has to do with the drywall getting wet and falling apart. greenboard will fall apart just like regular drywall when it gets wet it just takes longer. in many places it is against code to install drywall around a tub or shower.
Old 03-16-2013, 01:25 PM   #18
Rewards Points: 528
Alan, I used to do that but started reading install instructions. I have yet to see that as the proper way to install a tub.
framer52 is offline   Reply With Quote
Sump pump is pushing water up into the bath tub. Eh? roasted Plumbing 29 03-12-2017 07:59 PM
Should I install interior doors before floor? pttcc Flooring 13 11-23-2010 09:02 AM
Acrylic Tub Install Help mthompson73 Kitchen & Bath Remodeling 6 08-19-2010 06:30 PM
Oil- Acrylic Primer- Oil? blue_fox Painting 3 06-23-2010 11:32 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
