#1 |
ACQ rated fasteners
According to this article:
http://www.aces.edu/poultryventilati...5ACQLumber.pdf New pressure treated lumber uses different chemicals and can really cause corrosion if the proper fasteners are not used. I have seen posts made by pros saying their non-ACQ rated screws totally rotted out in 1 year. I have seen screws and nails that are ACQ RATED. My question is are standard stainless steel OK because it's "stainless"? Or one must get ACQ rated screws? I have a box of "SPAX stainless steel square drive screw" and I don't know if I can use it for todays PT lumber? |
#2 |
ACQ rated fasteners
Go for it.
#3 |
Civil Engineer
ACQ rated fasteners
Unfortunately it is not so simple. There are over 100 different types of stainless steel, and some of them apparently corrode readily in ACQ treated wood. For a full description of the performance of difference types of fasteners made of different materials, see http://www.nadra.org/industry_news/acqarticle.html.
The article is very careful to note how little is really known about fastener performance in ACQ, and it does not make specific recommendations, but if you read it carefully you will see that certain types (not brands) of stainless steel are listed as performing better than others. Unfortunately the specific type of stainless is not always listed on the box of nails, so it may be impossible to determine if the specific fasteners you have are of the type that are claimed to be resistant to ACQ corrosion. |
#4 |
journeyman carpenter
ACQ rated fasteners
just look for fasteners which clearly state ACQ rated on the box.. senco makes them. so does Paslode. Senco stainless steel will cost you a fortune though. i use their stainless 15 gauge nails and ring shank coil nails all the time for exterior finish work.. its the only thing that will last in a marine environment or with cedar or azek
#5 |
ACQ rated fasteners
I just use ceramic coated fastners. A whole lot cheaper and harder then stainless and will never rust out.
| Display Modes | |
| Hidden fasteners difficulties - TimberTech ConceaLoc | jim-in-ga | Building & Construction | 5 | 09-20-2012 06:57 PM |
| Meaning of Recessed Lights That Are "Not Rated for Insulation"? | DoItY | Electrical | 7 | 06-30-2012 01:00 AM |
| Structured Wiring Panel Location...Fire Rated Wall??? | RICKM15752 | Electrical | 0 | 04-20-2011 12:30 PM |
| Copper preservative & fasteners | ARI001 | General Discussion | 0 | 07-22-2009 10:08 AM |
| Non-IC rated lighting in Insulated cieling. OOPS! | MyMonkey | Electrical | 7 | 02-22-2008 10:46 PM |
