-   -   ACQ rated fasteners (http://www.diychatroom.com/f19/acq-rated-fasteners-174941/)
miamicuse 03-19-2013 10:48 AM
ACQ rated fasteners
3 Attachment(s)
According to this article:
http://www.aces.edu/poultryventilati...5ACQLumber.pdf
New pressure treated lumber uses different chemicals and can really cause corrosion if the proper fasteners are not used. I have seen posts made by pros saying their non-ACQ rated screws totally rotted out in 1 year.
I have seen screws and nails that are ACQ RATED.
My question is are standard stainless steel OK because it's "stainless"?
Or one must get ACQ rated screws?
I have a box of "SPAX stainless steel square drive screw" and I don't know if I can use it for todays PT lumber?
framer52 03-19-2013 11:13 AM
Go for it.
Daniel Holzman 03-19-2013 01:47 PM
Unfortunately it is not so simple. There are over 100 different types of stainless steel, and some of them apparently corrode readily in ACQ treated wood. For a full description of the performance of difference types of fasteners made of different materials, see http://www.nadra.org/industry_news/acqarticle.html.
The article is very careful to note how little is really known about fastener performance in ACQ, and it does not make specific recommendations, but if you read it carefully you will see that certain types (not brands) of stainless steel are listed as performing better than others. Unfortunately the specific type of stainless is not always listed on the box of nails, so it may be impossible to determine if the specific fasteners you have are of the type that are claimed to be resistant to ACQ corrosion.
woodworkbykirk 03-19-2013 04:18 PM
just look for fasteners which clearly state ACQ rated on the box.. senco makes them. so does Paslode. Senco stainless steel will cost you a fortune though. i use their stainless 15 gauge nails and ring shank coil nails all the time for exterior finish work.. its the only thing that will last in a marine environment or with cedar or azek
joecaption 03-19-2013 07:26 PM
I just use ceramic coated fastners. A whole lot cheaper and harder then stainless and will never rust out.
