-   -   Acoustical Insulation for basement ceiling (http://www.diychatroom.com/f19/acoustical-insulation-basement-ceiling-14786/)
newcondo 12-27-2007 02:19 AM
I am looking for the CHEAPEST way to stop noise travel throught the ceiling in my basement. I'm not looking for details here. I found R-13 Vapor faced insualtion for $0.24 a square foot. I was going to hang one batt against the ceiling. I was then going to double it up to create (in theory) and R-26 thickness. Now I need to know, since both batts are faced. Will there be a problem having one faced batt smushed inbetween? Make sense? OR am I creating a big mess and should I just spend the extra $250 and go with R-30 from the start. Remeber that I'm doing the work myself - so I don't care how long it takes - AND I am only insulating for sound. Any replies thoughts, would be great.
Tim
AtlanticWBConst. 12-27-2007 06:48 AM
You can buy R-13 batts Unfaced. Why don't you just use that?
(If your exterior basement walls are insulated, then you don't need a vapor barrier on that area's insulation anyways, since it is "inside" your home's thermal envelope.)
Big Bob 12-27-2007 07:29 AM
cheapest way?.....hmmm... tell everybody no walking or talking upstairs while you are in the basement....or wear ear plugs...?:jester:
you want your effort to give you your desired results. what noise are you trying not to hear?
jerryh3 12-27-2007 02:03 PM
Use resilient channel.
http://scafco.com/stud/channel.html
newcondo 12-27-2007 09:40 PM
Ceiling Insulation
Well - I like the idea of no talking/walking while I'm in the basement! But I've tried it - she ain't buying it. I am not insulating the walls, just the ceiling. I now know not to use faced insulation, good I'm one step closer. So I"m thinking of using R-19 or R-30. The sounds that I'm trying to drown out are walking on wood floors. TV noise and general noise. Dishes clanking etc. The resiliant channels are an option but not what I wanted to mess with. If I fing it's not too hard then I will try them. Thanks
Tim
AtlanticWBConst. 12-28-2007 07:28 AM
You could also contact a building supply company and ask them about "Sound attenuation blankets" - essentially, it is insulation that is designed to be denser - for fire-rating and for higher sound blocking capabilities.
Here's some links:
http://www.certainteed.com/NR/rdonly...F0/0/TF886.pdf
http://www.owenscorning.com/worldwid...24726ABP1P.PDF
http://www.idimn.com/pdfs/Insulation...fiber_SAFB.pdf
newcondo 12-28-2007 11:06 PM
Accoustical Insulation for basement ceileing
Thank you - this is actually EXACTLY what I was looking for. I probably crossed paths with this product early in my search (when I had even less idea what I was doing than I do now) and looked past it. Thank you very much. My mind is settled! Now can you help with this darn lighting problem I have- just kidding. I'll post later. Thank to every one. This forum is sweet.
Tim
KHouse75 08-25-2008 10:50 PM
http://www.greengluecompany.com/
Might be a little more expensive than what you are looking for but it works great. We soundproof home theaters with it.
