Acoustic Batts? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-29-2010, 09:46 AM   #1
Rewards Points: 27
acoustic batts?
Doing a bathroom re-do, and have the walls open. I recall hearing lots of "residual noise" coming from this bathroom when somebody was using it - so want to use some sound deadeners in the wall.
Would love to hear what others have used, trade-offs in price/effectiveness. And, where to get product? I can't seem to find any acoustic batts at any of the big boxes around here.
bamaranch is offline   Reply With Quote
Old 05-30-2010, 01:11 PM   #2
Drywall contractor
Rewards Points: 1,070
Sound attenuation blankets are available from a drywall/acoustical supply yard or an insulation company. It will help to some extent (and better than regular fiberglass ins.), but without other extensive modifications you'll still have sound transmission through fasteners, the door, etc.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 05-31-2010, 04:59 AM   #3
Rewards Points: 156
On thing I have done which works well for walls and ceilings is to pack it with insulation and then go to your local hobby store and buy a large sheet of felt. This stuff comes in rolls and is quite inexpensive. Now with hot glue attach the felt directly onto the facing of the stud on the front and rear, assuming both sides witll be sheetrocked. This puts a softer space between the sheetrock and lumber. Sound travels by vibration and the felt greatly reduces the vibration. It has worked well for me in the past and i will continued to do this.
ryan5068 is offline   Reply With Quote
Old 06-03-2010, 10:41 AM   #4
Never heard of sound deadening blankets. Available at big boxes?
HHac8014 is offline   Reply With Quote
Old 06-03-2010, 10:56 AM   #5
Rewards Points: 27
BJB, I am in Atlanta now, do you know of a place specifically that could carry such blankets?
Ryan, the felt idea sounds like it may be enough additive to the R-13 to be enough. It's not like I'm trying to have buffer a music studio or something - just keep people in the living room from knowing way too much information about how somebody's bathroom experience is going. Felt and R-13 may be enough.
Old 06-04-2010, 03:49 AM   #6
Rewards Points: 156
If you are looking to just dull the sounds of voices and or bathroom noises the felt and R13 would be totally sufficient. I have had excellent results using this in a theater room and it does a really nice job. I would at least give it a shot compared to spending quite a bit of money on deadening blankets and such. Felt is cheap and so is R13.
Dividing or packing in insulaton batts...which would work best? Hossenfeffer Building & Construction 8 04-13-2010 01:06 PM
plastic ductwork vs. metal: acoustic duct liners jjpclev HVAC 5 02-26-2010 08:29 PM
What Thickness Drywall To Install Over Acoustic Ceiling? dsq Drywall & Plaster 12 02-08-2009 08:27 AM
Kraft Faced Batts in Interior Wall Earnie Building & Construction 2 01-24-2008 09:52 AM
acoustic insulation amakarevic Building & Construction 1 05-25-2007 10:32 PM
