Acceptible Material For Fireblocking Chase - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-21-2011, 06:54 AM   #1
Acceptible material for fireblocking chase
Can I glue or screw two sheets of 1/2 plywood together to thicken it up to use as fireblock in a plumbing chase? I have the plywood available and did not want to buy a new sheet of osb.
toobhed is offline   Reply With Quote
Old 10-21-2011, 07:00 AM   #2
Framing Contractor
Call the building inspector and ask because he/she will have to inspect that anyway.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 10-21-2011, 07:06 AM   #3
the Musigician
DangerMouse's Avatar
Like Joe said, call and ask. But I don't see a problem at all with it.
DM
Old 10-21-2011, 07:07 AM   #4
kwikfishron's Avatar
Rewards Points: 596
I’ve never used plywood or osb to block anything in a frame.
As mentioned, ask the inspector.
kwikfishron is online now   Reply With Quote
Gap-filling material for r.r. tie sidewalk Hi Country Home Building & Construction 1 05-28-2011 08:58 PM
Water Fall - Black bonding material cprao Landscaping & Lawn Care 3 04-23-2011 03:06 PM
Flashing decking around fireplace chase kwerk Building & Construction 0 10-28-2010 11:48 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 07:41 PM
