Is This Acceptable For A Wood Fence? - Building & Construction - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-22-2009, 06:16 PM   #31
I've seen a lot of fences
I've NEVER seen that method before
Old 04-22-2009, 06:25 PM   #32
Rewards Points: 352
As long as the posts are planted firmly and deep enough I don't see 4 1/2" (3 - 2X4) being enough to be a problem. That said what I see would make me suspect of the quality of the work.
Rege
RegeSullivan is offline   Reply With Quote
Old 04-22-2009, 06:29 PM   #33
Rewards Points: 1,232
I have built a lot of fences and I would never consider that method. How does a tree create that situation? It is either in the way or not. Stumps/rocks I can understand, but you allow for that as you dig the holes and set the posts laterally. That is, if you have to move 2 foot to the left, you also have to move the remaining posts 2' to the left to maintain post spacing.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 04-22-2009, 08:43 PM   #34
CrossWorks's Avatar
Rewards Points: 150
Originally Posted by mgraeber View Post
That was after he suggested that it was probably done to avoid stumps or trees. The next time I talked to him, he said that he had talked to his boss and to the guy who had done the work, and that it had been done to avoid stumps or trees.
Forgive me if I'm wrong here but; Sounds to me like you may have inadvertently asked (before anything was ever mentioned) if the posts were that way, because of stumps or trees. Once they heard that question coming from you, they in turn got toegther, talked it over, and when he came back cynically agreed with your assumption, thus "in some foolish way" thinking he had cleared themselves of bad judgement. Besides they may have assumed that you wouldn't know any different.
Look, I've dug many holes in the past 25 years and I have what is called a "pinch bar" specifically for cutting roots that are deeper then 24", and they normally are no bigger in diameter then 5". If their on the surface, my gosh, that's what my Sawsall is for!!
Besides, you say that some of the post don't have trees near them to justify the post misalignment
but as far as I can tell, the others didn't happen because of trees or stumps.
I'm beginning to smell a dead fish here. Call a lawyer! The pictures of this mess will speak for themselves. There's nothing to hide, not even incompetence!!!!! And or neglect! Now my stomach is turning
Don't let'm get away with this. If they had said ledge or a giant boulders was the issue, that's understandable, but in this case their knee deep in deception & lies. AAAARGH!
A great personality will open many doors in life,
but it's your character that keeps them open!
www.crossworksme.com
"Where Every Nail Has a Purpose!"
CrossWorks is offline   Reply With Quote
Old 04-22-2009, 09:00 PM   #35
knewbie
curapa's Avatar
Although cutting roots out of the way is deffinately an option, you have to consider the damage that will be done to the tree. Most people would rather move a post than pay $1000 to have a large tree removed. Disease can easily get to the tree when roots are cut underground causing it to die.
ParkerFenceandDeck.com
curapa is offline   Reply With Quote
Old 04-22-2009, 09:13 PM   #36
CrossWorks's Avatar
Rewards Points: 150
With all due respect curapa, your missing the point! But I understand what your saying, and as contractor I would clearly bring it up to the customer if I was about to cut a major root vain. But it is rare, and most roots I've encountered were minor in size.
Old 04-22-2009, 10:06 PM   #37
I asked about surveying the property, and they asked if we had a plat map (we found 3 of our 4 corner markers), but then they didn't ask for it once they got to the site.
That would concern me a bit,one of the first things I ask about is property markers and if they aren't there I won't do the install until they are set.If they fenced you're entire yard having 3 of 4 pins is not good.
[QUOTEIt is true that they were working at the edge of a wooded area (so I would like to know if it is unreasonable to expect them to fix it). ][/QUOTE]
I would be wondering if they even used a string line between the pins.No it is not unreasonable to have them fix it I would demand it.
Same here and I couldn't agree more.
snake2k is offline   Reply With Quote
Tags
fence , please help , privacy fence , wood fence
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Cedar Wood Fence - Staining again ddave23 Painting 13 03-22-2012 05:43 AM
DIY Replacement of a Wood Fence rcraftlady Building & Construction 4 03-11-2009 06:03 PM
Preferred Fence Wood? Medium_Pimpin' Building & Construction 2 07-06-2007 09:21 AM
