Acceptable Footing/foundation Dimensions Deviations - Building & Construction - Page 5 - DIY Chatroom Home Improvement Forum
Old 11-08-2011, 01:28 PM   #61
Old School
Willie T's Avatar
Originally Posted by James58 View Post
Yes, when you depress the bolt, there can be a 1/4" depression around the bolt shaft. I usually just smooth it by finger. Its never been an issue. To each his own, i guess.
That's the point. It's not "to each, his own". In much of my work there are volumes of exacting specifications and requirements that the Government checks you very carefully on. And if you are not right, the whole task can be required to be done all over again.
I have done some concrete pours that required temperature sensors placed into the concrete (and left there) in dozens of places to record on an electronic monitoring graph, the curing temperatures over a 24 hour period.
There's a whole world of very serious building going on out there.
Willie T
Old 11-08-2011, 01:38 PM   #62
JOATMON
ddawg16's Avatar
Rewards Points: 802
Do you actually do this? Must be fun vibrating, and troweling off.
It takes 5 min to set anchor bolts. If the mud is the right consistency (just wait) the bolts don't sink, and because you are a carpenter, an 1/8th inch of perfection is second nature to your hand and eye.
It's obvious that building techniques are different in your part of the country....that would not work here. Part of the problem is that trying to shove a 16" long L bolt down into the concrete and not hit the rebar is going to be tough....good luck pushing an SSTB or SB 1x30 down into wet concrete....and missing the rebar. In other words, not going to happen.
Originally Posted by Anti-wingnut View Post
On big stuff like multi-family, commercial and industrial, as well as high siesmic areas, you gotta get the anchor bolts where lay-out and engineering says they go. It's really quite common to have to place them on top of the forms, and to be inspected prior to pour
Yep....pretty much how mine went. Using the drawings, I marked on the form where each one went....then used wire or wood to hold them in place. For the standard anchor bolts, I used those blue holders that you nail to the side of the form. But at a buck each....I ended up using wood for a lot of them. That actually made it easier to set the height....
In real terms...the hold down bolts need to be within about 1/4" of target, otherwise, you are going to have issues with the hold down. On those hold down bolts that go up through my sub floor....I have a lot more wiggle room....a sledge hammer works just fine for adjusting.
ddawg16 is online now   Reply With Quote
Old 11-08-2011, 01:49 PM   #63
I've been on jobs where we had 900 anchor bolts
Right, that's a good point. Try setting that by hand
James58 is offline   Reply With Quote
Old 11-08-2011, 01:55 PM   #64
Well of course, but i am talking about residential SFD, not the Parliament buildings lol. I've never built anything i didn't take seriously. As a framing carpenter you are responsible for holding up the roof. That always seemed dead serious to me.
Old 11-08-2011, 02:08 PM   #65
What about placing Simpson mudsill straps and the such in the concrete?
How would one run anchors or "j-bolts" in the slab of an ICF home?
JackOfAllTrades is offline   Reply With Quote
Old 11-08-2011, 05:02 PM   #66
Rewards Points: 1,002
As per the manufacturer, engineers or equivalents detail
Anti-wingnut is offline   Reply With Quote
York external filter racks dimensions raylo32 HVAC 2 09-14-2011 06:22 AM
fireplace dimensions on older home...can it burn wood? JPinSD General DIY Discussions 6 12-18-2010 09:40 AM
Help With Bathtub Dimensions... Jamaro85 Plumbing 3 11-02-2009 10:48 AM
Wrong Footing Dimensions HELP jhernan35 Building & Construction 2 04-15-2007 03:22 PM
Dimensions of ac condensors rjordan392 HVAC 3 06-04-2005 02:37 PM
