Acceptable Cuts In 2x10 Band Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-17-2010, 04:19 PM   #1
Acceptable cuts in 2x10 band joist
Hello,
I need to cut a semi-circle out of 2x10 band joist so I can run conduit up from my first floor (I'm installing coax and network cable). Can I safely cut a 1 inch diameter semi-circle out of the inside edge of the 2x10 or will that ruin the integrity of the board? This cut will fall about center between two joists.
Here's a link to a rough drawing of what I'm talking about in case I can't figure out how to attach the picture to this post. Thanks for any help!
http://i898.photobucket.com/albums/a...s/JoistCut.jpg
oatlord is offline   Reply With Quote
Old 09-17-2010, 09:29 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 398
You should be fine with that.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following 2 Users Say Thank You to BigJim For This Useful Post:
jlhaslip (09-18-2010), oatlord (09-17-2010)
Old 09-17-2010, 09:37 PM   #3
Rewards Points: 5,336
In NY, this would be a rim joist over a sill plate.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
BigJim (09-17-2010)
Old 09-18-2010, 12:19 AM   #4
Rewards Points: 1,910
I doubt you need to use conduit for coax and network cable. If you want to set it up so you can add additional cables later you could just include a pull line with the initial bundle you snake through.
Old 09-18-2010, 09:56 AM   #5
Chicago, IL
Michael Thomas's Avatar
The primary things to watch for would be the attachment of something (for example a porch ledger) through the thinned portion of the band joist, or a highly concentrated point load (for example the post supporting one end of a heavily loaded header) applied at that point.
Not likely problems, but still things to keep in mind....
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Bad tile cuts krush Flooring 5 06-18-2007 09:15 AM
Any way to allow a 3.5" bore through a 2x10 floor joist? peeks Building & Construction 1 07-06-2005 02:02 PM
