Is Abestos Present Normally In Homes Built Around 1979 To 1981? Pics Included - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-21-2012, 09:38 PM   #1
Rewards Points: 320
Is abestos present normally in homes built around 1979 to 1981? Pics included
Was working on my parents' home, they wanted me to redo a small portion of their garage ceiling drywall due to a roof leak. When I was removing the portion of the ceiling a bunch of loose fill insulation fell. I was wearing a general dust mask and goggles.
But I was just wondering, from what I remember just hearing from random people, they stopped using asbestos in homes by 1970 right? The house was built between 1979 and 1981, and without getting it tested, just was seeing if this loose fill insulation could have asbestos in it. The loose fill insulation looked a bit brown, but it could be due to the water from the roof leak discoloring it? I kind of remember some parts of the dry loose fill insulation looked grey, like cellulose, but I have to go to their house to check.
Attached some pictures to show. I may get it tested since I'm a bit of a hypochondriac, Thanks in advance
Oh, and as you can tell, one of the photos shows the ceiling prior to me cutting it out.
Is abestos present normally in homes built around 1979 to 1981? Pics included-img_2247.jpg   Is abestos present normally in homes built around 1979 to 1981? Pics included-img_2249.jpg   Is abestos present normally in homes built around 1979 to 1981? Pics included-img_2239.jpg   Is abestos present normally in homes built around 1979 to 1981? Pics included-img_2246.jpg
amodoko is offline   Reply With Quote
Old 10-21-2012, 10:03 PM   #2
DIY staff
Rewards Points: 7,174
It's unlikely with the age of the home---but possible----for good measure---spray the garage with water as you sweep to keep any of the dust from going airborne---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
amodoko (10-23-2012), AnnContorno (10-22-2012)
Old 10-21-2012, 10:28 PM   #3
Rewards Points: 320
Thanks oh'mike, I thought it was unlikely to contain asbestos as well. Good idea about the water too.
Old 10-22-2012, 02:04 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,500
Here is a good link to possible asbestos issues in a home...
http://www.cpsc.gov/cpscpub/pubs/453.html
Where Asbestos Hazards May Be Found In The Home
  1. Some roofing and siding shingles are made of asbestos cement.
  2. Houses built between 1930 and 1950 may have asbestos as insulation.
  3. Asbestos may be present in textured paint and in patching compounds used on wall and ceiling joints. Their use was banned in 1977.
  4. Artificial ashes and embers sold for use in gas-fired fireplaces may contain asbestos.
  5. Older products such as stove-top pads may have some asbestos compounds.
  6. Walls and floors around woodburning stoves may be protected with asbestos paper, millboard, or cement sheets.
  7. Asbestos is found in some vinyl floor tiles and the backing on vinyl sheet flooring and adhesives.
  8. Hot water and steam pipes in older houses may be coated with an asbestos material or covered with an asbestos blanket or tape.
  9. Oil and coal furnaces and door gaskets may have asbestos insulation.
ddawg16 is online now   Reply With Quote
The Following 3 Users Say Thank You to ddawg16 For This Useful Post:
amodoko (10-23-2012), AnnContorno (10-22-2012), jimmy21 (10-22-2012)
Old 10-22-2012, 06:52 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
What you have appears to be cellulose insulation, which would not contain asbestos. Don't be led to believe that all asbestos was banned from all products in the U.S.
Between 2000-2007, the U.S. imported 110,000,000 pounds of the stuff. And that was just for use in manufacture in the U.S. Who knows what is coming in products manufactured off shore?
Regarding the previous list, #2, Houses that have had vermiculite installed as insulation may well be later than the 1950s.
#9. All kinds of high temperature insulation on stoves, ovens, water heaters and boilers can contain asbestos, including the breaching and pipe cement on exhaust stacks.
I've seen it in caulking, drywall, drywall compound and acoustical tiles too.
Is abestos present normally in homes built around 1979 to 1981? Pics included-acm.jpg
The Following User Says Thank You to Maintenance 6 For This Useful Post:
Old 10-22-2012, 10:35 AM   #6
jschaben
Rewards Points: 502
I don't think you have asbestos, that looks like black mold though.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
The Following User Says Thank You to jschaben For This Useful Post:
Old 10-22-2012, 12:39 PM   #7
Good reminder on making sure it's wet before you start clean up...something that I forgot!
AnnContorno is offline   Reply With Quote
Old 10-22-2012, 01:43 PM   #8
Sound's unlikely that 's asbestos, but you need to get specialists in to remove the stuff.
Gissle is offline   Reply With Quote
Old 10-22-2012, 03:33 PM   #9
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,124
mold is very likely, even though it was banned at that time frame it could still have traces in the insulation,
woodworkbykirk is offline   Reply With Quote
Old 10-22-2012, 05:10 PM   #10
Civil Engineer
Rewards Points: 4,702
Contrary to common wisdom, asbestos containing products are still perfectly legal in the United States, and are still in use. The main supplier of asbestos mineral is Canada, which still sells asbestos mineral for use throughout the world. The EPA lost a court case in which it sought to ban asbestos outright.
By the way, the word "asbestos" is not actually defined by the EPA, they typically refer to "asbestos form fibers". There are several dozen different minerals which can be processed to create long, very small fibers, which are strong, essentially fireproof, and have been used in an astonishing variety of products over the years, including insulation, brake pads, tiles, roofing material, siding, paint, countertops, you name it. The ONLY way to know if a particular product contains "asbestos" is to have it tested by a laboratory. It is much less likely that a recently constructed house contains "asbestos" than an older house, but anyone who assures you there is some magic cutoff date is mistaken.
That said, "asbestos" is only considered to be dangerous when inhaled. The EPA contains a pretty decent website explaining how to test for asbestos (this takes a lab, cannot be done visually), and how to clean it up and dispose of it.
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
amodoko (10-23-2012), chrisn (10-23-2012)
Old 10-22-2012, 05:19 PM   #11
liscenced electrician
Rewards Points: 538
That insulation doesn't contain asbestos but still not good to breath. Probably contains mold and mouse poop. I always set up a couple box fans and I always take a break after a big cloud forms from dropping big pieces. Use a respirator also
jimmy21 is offline   Reply With Quote
The Following User Says Thank You to jimmy21 For This Useful Post:
Old 10-22-2012, 05:20 PM   #12
Too Short? Cut it Again!
I paid a price in the form of a loose diagnosis of "environmental pneumonia" once for boldly crawling around, cares to the wind and demo-ing antique homes. I don't think I ever breathed in asbestos fibers but I am now diligent about wearing at least dust masks if not an aspirator working around any insulation and airborne dust.
The Following User Says Thank You to user1007 For This Useful Post:
Old 10-23-2012, 04:05 AM   #13
paper hanger and painter
chrisn's Avatar
Rewards Points: 316
Ahhh, to be young and dumb. I once had to retrieve a spray tank lid that fell into the bottom of a 600 gallon tank full of DDT
not dead yet and still fathered my only child
Old 10-23-2012, 01:58 PM   #14
For a minute I thought you said 'moose poop' i was thinking 'how could a moose get up there' lol!
Costs estimate help please for a newbie Basement vs crawl space Cancer Researcher Building & Construction 21 03-30-2012 06:59 AM
