9' Garage Door Header - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-23-2010, 03:24 PM   #1
9' garage door header
My 9' garage door solid header had rot on the right half which I removed.
The remaining header is 10"x10" on the left untrimmed side but narrows on the right side to a trapezoid measuring 10" vertical, 4.5" on bottom and 9.5" on top.
So the beam at the weakest point has at least the strength of a 5"x10" header.
Is this enough for a flat roof with max snow load of 1'. The narrowest spot in the header is five feet from the corner of the roof.
Last edited by ifixfxs; 05-23-2010 at 11:13 PM. Reason: didn't take quotation marks for inches
ifixfxs is offline   Reply With Quote
Old 05-23-2010, 08:19 PM   #2
Rewards Points: 5,336
The post is unintelligible. Look it over and repost.
Ron
Old 05-23-2010, 09:46 PM   #3
Rewards Points: 1,910
I understand you want to replace a rotting header. The rest I don't understand except that you aren't sure about size. Is there some reason you don't want to replace it with the same size that was there?
Old 05-23-2010, 11:20 PM   #4
Replacing the header may not be necessary if the remaining header is adequate. We use over sized beams in Santa Fe for style. My hope is to build a false cover to conceal the missing portion which is about 25% of the cross sectional area of the header. Cost difference between this and replacement is about $300 vs $3000
Old 05-24-2010, 07:01 AM   #5
I also didn't understand the OP question.
rburke65 is offline   Reply With Quote
Old 05-24-2010, 01:15 PM   #6
Registered User
Rewards Points: 526
OP: "Is this enough for a flat roof with max snow load of 1'." ---------- NO. Not when the builder used a minimum 10x10" header because he had to pass inspection or the Engineered plans called it out. You now have 1/3 as much left, how would that suffice?
"So the beam at the weakest point has at least the strength of a 5"x10" header." ---- A structural Engineer evaluated this? Or are you guessing?
1. Where are you located?
2. What is the load? Joist span? Trusses bearing- span? Rafters/ceiling joists? Storage on c.j.s?
Be safe, Gary
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 10:21 PM
Garage Insulation DIYguy2000 Building & Construction 2 12-09-2009 07:41 AM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
