80 Kg Plaster For One Room !! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-15-2011, 09:50 PM   #1
GBunny
Rewards Points: 71
80 kg plaster for one room !!
Is it possible to it would take 80 kg of drywall compound when doing the seams on one 12 x 27 room (excluding seams where there is crown molding)? Just questioning some bills from contractor. Is it customary for that I should pay for work light, trowels, etc.?
GBunny is offline   Reply With Quote
Old 04-15-2011, 10:51 PM   #2
joed's Avatar
Rewards Points: 13,752
If you paid for them they should leave them behind for you.
Old 04-15-2011, 11:01 PM   #3
You should not have had to pay for tools used. That is a business expense. What exactly do they have on the invoice you have. I know the companies that I have worked for have never charged anyone for the tools we use other than if one of the clients were using it and broke it or something along those lines.
ahrens is offline   Reply With Quote
Old 04-16-2011, 08:12 AM   #4
Rewards Points: 5,336
That's 180 lbs(about 3 buckets of compound). Seems more then reasonable. Tools and work lights seems odd unless you have an unusual contract with them.
Ron
Old 04-16-2011, 08:49 AM   #5
the Musigician
DangerMouse's Avatar
THREE 4.5 gallon buckets of mud for one room????? Ummmmm.....
DM
Painting room finally Imkindofbigdeal Painting 10 03-16-2011 03:22 PM
Right materials to patch plaster on masonry? jimhome Remodeling 3 06-08-2009 11:23 AM
A room in a room? artosie General DIY Discussions 2 03-10-2009 12:43 PM
Plaster ceiling and drywall desrtrat Drywall & Plaster 13 10-08-2008 07:20 AM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 05:27 AM
