8 Month Old Modular With Flooring Problems?? HELP!! - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-26-2006, 01:25 PM   #1
8 month old modular with flooring problems?? HELP!!
We moved into our home about 8 months ago. It is an off frame modualr. We purchased it from a realtor in the area, who bought a huge track of land, and put of three modualrs which are identical. I have noticed that our flooring is quite eneven the last few months. Which I am sure is due to settling. However, I am not sure what is considered "normal settling" and what is not. There are lots of noticable dips in the flooring all over. Not so much noticable by sight, but you can feel it when you walk on the floor. I noticed under our home ( we have a cement crawl space) that the only support system it has are cement and cynder block columns down the middle of the home. I know we have a one year manufacture warranty on the home, but would something like this be covered under the warranty? Does anyone have any advice as far as what steps me should take, if any? Thank you!!!
SomewhereInNC is offline   Reply With Quote
Old 07-26-2006, 06:26 PM   #2
Do the other homes have the same problem?
Is the warranty on the entire home (foundation, house...) or just the modular aspect?
If the entire home (foundation and all) is under warranty then I would take photos of the problem. Both inside the home and under the home. Send a certified letter to the warranty holder that there are problems that need attention - before the warranty expires.
redline is offline   Reply With Quote
Old 07-26-2006, 11:11 PM   #3
Foundations do not 'settle'
Properly installed foundations do not settle.
Modular homes are warranted on other than building code criteria.
You need to go back to see what the original equipment manufactuer's installment guarantee period is....
You need to review just what your seller's guarantee and period is.
Does NOT sound like any "settling" problem. (Homes normally do not "settle")
Sounds like a floor sheathing and/or underfloorspace moisture problem.
manhattan42 is offline   Reply With Quote
modular home flooring problem wen Flooring 10 Yesterday 02:32 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 03:51 PM
8 month old modular with flooring problems?? HELP!! SomewhereInNC Flooring 1 07-27-2006 01:46 AM
Gameroom basement flooring? PaulMcC Remodeling 4 03-09-2006 09:08 AM
IAQ and flooring. Briefly. Benhamcarpetguy Flooring 12 03-24-2005 08:53 PM
