8" Deck Pier? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-22-2012, 07:12 AM   #1
Rewards Points: 85
8" deck pier?
Hi everyone, need your opinion, please.
I am going to build a deck this summer, size 10'x16', 6' measure from the deck floor to the ground, joist span about 71/2', beam span about 55", beams and joists are 2x8, post 6x6,the deck will be free standing due to brick veneer finish.
Hire the contractor to put 8 piers, 4' in the ground, 10" pier agreed on. Low and behold, he only put 8" sonotube down.
Do you think 8" will be ok due to the amount of piers or the size of the deck?
Get you opinion before i talk to the contractor and the inspector next week.
I am in Toronto, Canada.
Thanks in advance.
quincy is offline   Reply With Quote
Old 04-22-2012, 07:44 AM   #2
Electrician
Rewards Points: 794
Is 10" in a written contract, if so tell him to get out there and put the right size tubes in.
darren is offline   Reply With Quote
Old 04-22-2012, 08:17 AM   #3
Civil Engineer
Rewards Points: 4,772
The minimum required pier size is usually a code driven issue. Consider that concrete has a compressive strength typically of a minimum of 3000 psi (too early in the morning to convert to metric units). The area of an 8 inch pier is about 50 square inches, so the concrete can support in theory 150,000 lbs, which greatly exceeds any load you will put on it. So the soil strength always controls required pier diameter.
Soil strength is much more difficult to estimate, a strong soil may have strength up to 5,000 lbs/square foot, while a weak soil may be good for less than 500 lbs/sq ft. The allowable strength of the soil per square foot also goes up the deeper the footer is embedded. Because of the mostly unknown properties of the soil at your location, code generally specifies a minimum footing diameter, and a minimum depth, which is typically below frost, so 4 feet sounds about right for you.
I don't know what Canadian code requires for minimum diameter, where I live in Massachusetts we run on the International Residential Code for decks. My town uses the 2006 code. Table 4 presents minimum footer sizes, which vary with the beam and joist span. This table assumes minimum 1,500 psf soil bearing capacity. The table is not really applicable to sonotube installations, so in my town the code enforcement official generally sits down with each applicant before construction and approves the size of sonotube to be used. In my case, I presented 10 inch tubes, and that is what I used.
Where I live, if you want to deviate from an approved plan, you need an engineer's letter stating the reason for the deviation, and stating that in the opinion of the engineer the deviation is safe and acceptable. Assuming you had an approved plan showing 10 inch footers, but the contractor failed to read the plans and deviated, perhaps the contractor can obtain an engineer's certification that the 8 inch posts are OK. If they cannot, and your building official does not approve the deviation, the contractor really should replace them with the agreed upon size at no cost to you.
Old 04-22-2012, 08:45 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
FWIW - In my region, 12" dia. is the code required norm in many towns/cities. As stated, you should check with you local building dept, among the other good suggestions made.
- Build Well -
Old 04-23-2012, 09:08 AM   #5
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
One more vote for calling the town and see what they want. Technically my plan called for 10" tubes, but the local buidling dept wanted 12".
CoconutPete is offline   Reply With Quote
Old 04-23-2012, 11:18 AM   #6
concretemasonry's Avatar
Rewards Points: 2,608
In Winnipeg, you may need than 4' depth. Your soils there can be highly variable and I think a quick shallow sampling of the soil will tell you about the soil area under a Sonotube should be.
Dick
concretemasonry is offline   Reply With Quote
Old 04-23-2012, 11:35 AM   #7
cortell's Avatar
Rewards Points: 504
Every box store in my area (there's one every square mile in this city, BTW) carries 8" and 12" sonotubes. 10" requires special ordering. That has always bugged me as 8" is a little too tight for a 4x4 post, and 12" is excessive.
Anyway, I wonder if your deck builder didn't hit the same availability issue. Seems to me, though, he should have explained it to you and made a case for using 8", given that your agreement with him stated 10".
I would, as has been suggested by other posters, give him the option to get approval for 8" from the local building code or from an engineer. Both will require legwork and the latter will additionaly incur a non-trivial cost. You can give him a second option, though: remove the existing piers and put in 10" ones. It's doubtful he'll like any of those options, but he put himself in this situation. It's unfortunate to see a red flag so early in a project. I hope the rest of the build goes smoother.
cortell is offline   Reply With Quote
Old 04-23-2012, 05:16 PM   #8
Electrician
Rewards Points: 794
Dick
I believe they tell us to go 6 feet deep for sono tubes, but I always thought that was for frost.
Old 04-23-2012, 07:09 PM   #9
Rewards Points: 85
Talked to the concrete contractor, this is how he did it: drilled with 10" auger 4' deep, fill the hole with concrete to the ground surface, put 8" sonotube around 8" -12" long into the concrete with about 6" above the ground, fill the tube with concrete then place the metal bracket for the 6x6 post on top of the concrete, the tubes and brackets are align perfectly.
So, technically it is 10" hole/pier.
What is your opinion on this method?
I am still waiting for the inspector.
Thank-you all for advises so far.
Old 04-23-2012, 07:31 PM   #10
cortell's Avatar
Rewards Points: 504
This sounds acceptable to me as long as it was a monolithic pour--not done in two phases.
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 11:36 AM
deck pier questions amakarevic Building & Construction 4 09-15-2010 08:47 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
