8" Cinder Block With A Brick Ledge On Top? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-12-2011, 10:22 PM   #1
8" cinder block with a brick ledge on top?
We have started construction and My bottom level is made of 8 inch cinder blocks. We are thinking from going from hardie planks or shingles to now bricks, is there a way we can have a brick ledge on top of that?
adam1979 is offline   Reply With Quote
Old 07-12-2011, 10:30 PM   #2
Rewards Points: 5,336
You started construction on what, exactly?
Ron
B. Franklin 1759
Old 07-12-2011, 10:35 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Okay got that part! What do the cinder blocks rest on?
Okay now I'm lost. What are "now bricks"? Are you saying "new bricks"?
On top of what?
Let's try again.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
mustangmike3789 (07-12-2011)
Old 07-13-2011, 01:05 PM   #4
Concrete & Masonry
Rewards Points: 530
Unless you want to shrink the house for the brick, simply lay another wythe of 4" block down to the footing and backfill it.
jomama45 is offline   Reply With Quote
Old 07-13-2011, 04:46 PM   #5
concretemasonry's Avatar
Rewards Points: 2,578
You will not be able to buy a cinder block unless you have deep pockets since they have not been made for decades.
If you have made the mistake of not planing ahead or not having good plans, in some areas you can get a special block for the top course to provide a legal brick ledge (depending in the above grade wall width). The block has a top wider than the bottom, but they are rare due to the need for them.
On my lake home, I used 14" thick block (a small amount of material and labor cost) to build a foundation/basement for a upper exterior wall of 4" clay brick veneer, 2" insulation/air gap and 8" block walls. Since I bought the block, the contractor would lay 10", 12", 14" block or 16" block for the same price. A little more for 4" if it was exposed. The result was a good finished job with no detail, insulation or waterproofing problems. I could have corbelled out the buried wall thickness ot used a block with top 2" wider than the base, but it was not worth the trouble.
Dick
concretemasonry is online now   Reply With Quote
Old 07-13-2011, 10:08 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
I may be understanding it all wrong also but if you have a wide enough footing to set the brick on there shouldn't be a problem.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 07-13-2011, 10:28 PM   #7
If you are doing a full basement depth, some people like to save a few pwnnies on a smaller width block and just used a corbelled block(2" wider at the top), but any masonry can be corbeled out, but most contractors like to do it the straight forward approach.
I have also seen basements built with a separate layer of 4" block just to support the brick (cheaper material and labor) and the transition from 4" block to brick can be tailored to the finished grade.
In my case, I used 14" wide block x 16" long because they were available in stock and it was easier for everyone, especially the contractor. But the "Cadillac" of walls (8" super lightweight block, 2" XPS styoroam and 4" clay brick) is rare on residential but is used on some commercial work.
The width of the footings are usually too much, but contractors like to use a stanard modular dimension (16", 20", 24") since the concrete is cheap and it gives a little extra room so prelimary layout does not to be as exact. - Nothing to do with the vertical load usually.
Dick
Brick Ledge when using cinder block DaveMo Building & Construction 5 07-13-2011 10:46 AM
Insulate Top of Cinder block wall HooKooDooKu Building & Construction 0 01-20-2010 11:58 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-06-2009 12:02 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Requirements for doorway in Brick and Cinder block sandyman720 Building & Construction 5 03-07-2007 10:48 PM
