Old 10-05-2009, 11:07 AM   #1
75 year chimney leak problem
I have a 75 year old cape cod home located on the south shore of long island, ny, with a brick chimney & slate roof. We have a second floor bedroom that has always leaked where the chimney is attached. The leaks appear by the ceiling at the roofline and spread as time progesses. Besides the continuous leaks, the chimney is badly spalling (large pieces of brick facing chipping off) above the roof line only - the rest of the brick on the front of the house require little maintenance.
We have attached the problem from two fronts: the roof was re-flashed and tarred several times to a point where the roofers point to the brick chimney as the problem; the chimney was painted, waterproofed, and sealed several times (it has always been painted) - yet the problem persists with the brick deterioration and leaks. We have gas heat (converted from oil 15 years ago), gas hot water, and have converted our fireplace from wood-burning to gas logs. Some contractors have suggested replacing our clay chimney liners as well with steel - something we haven't done. Based on what I've read, rebuilding the chimney above the roof line appears to be one of the better options available.
Given this, I would appreciate advice on how to approach fixing this problem and the types of contractors I should call.
thank you for any help in this frustrating and damaging problem
mike
mstanleyg is offline   Reply With Quote
Old 10-05-2009, 11:23 AM   #2
Can you put a photo on? Thanks.
stuart45 is offline   Reply With Quote
Old 10-05-2009, 03:36 PM   #3
thanks for the quick response
Old 10-05-2009, 04:23 PM   #4
Unfortunately painting brickwork often causes more damage to it than protecting it. Once it starts to crack and peel water running down the face enters the cracks but becomes trapped and soaks inside. When it freezes the bricks often spall. Paints have trouble in adherring to most types of brick and stone. Read this. http://www.icipaints.co.uk/support/s...es_plgn502.jsp
The oversailing courses are not offering much in weather protection to the stack either. Nowadys we always put in a lead tray that goes through the stack and round the liner to help prevent dampness below. http://justlead.co.uk/dpc-chimney-tray.html
It is quite a big stack to rebuild.
Old 10-05-2009, 05:00 PM   #5
It sounds like you have tradesman who do not know what they're doing working on this. Tarring over flashing is a vain and useless endeavor done by inexperienced people. If the flashing is suspect, have someone evaluate it and have it done correctly if it's the issue.
You don't mention the chimney cap. What shape is it in? At 75 years old, it should have been replaced by now or at least extensively renovated.
Ron
Old 10-06-2009, 09:39 AM   #6
Thank you both for your replies!!
Stuart45: Unfortunately, the brick has always been painted. If the stack needs to be rebuilt, any recommendations on how I should treat it (paint it like the rest of the brick, cover it, leave it alone)? Also you pointed out the size of the stack - do you think rebuilding it is necessary - or are other options available? Thanks for the lead tray information - something I will discuss with the contractors I see.
Ron6519: The cap was rebuilt about 25 years ago and seems to be in good shape. The tarring was done over the years after the flashing was redone about the same time - the tar buildup grew with the continuing problem with the leaks.
I have some contractors coming later this week. Are there any obvious directions I should follow? Also, in the past, someone recommended a steel line installation - how can one determine if one is needed?
thank you again for your advice and help
Mike
Old 10-06-2009, 11:23 AM   #7
"Also, in the past, someone recommended a steel line installation - how can one determine if one is needed?"
The chimney has a fired clay liner. It will deteriorate first at the very top of the chimney. You can go up and inspect the liner on a ladder for the best way to see it, or you can pull the flue pipe out of the wall in the basement to check for a pile of clay pieces on the bottom.
Since you have a fireplace, you should inspect both flues while your at it. Both of the clay flues are made up of segments of pipe cemented together. You want to make sure these connections are sealed together, especially in the fireplace. Embers can escape a deteriorated liner and possibly come into contact with wood framing members. To do a through inspection, you would need to put a camera down the entire length of the flues to make sure they are sound.
If the flues have deteriorated, then you could put a stainless steel liner into the chimnet to provide a continuous path to the roof.
This will not address the moisture/roof leak problem.
Ron
Old 10-06-2009, 12:09 PM   #8
Make sure the flashing on the chimney includes counter flashing too. The counter flashing is an inverted L-shape (actually more complicated than this but I'll keep it simple) where the short leg of the L in inserted into the mortar joints of the chimney. The long leg then extends downward covering the angle flashing that is woven into the shingles when the roofing is installed.
Too many modern day roofers/masons do not install counter flashings. Instead, they rely on mastics and caulks to seal the angle flashing against the brickwork until the warranty period has long expired. The old way is still the best way! Perhaps augmented with, but not replaced by, modern sealant technologies.
Yes, a chimney liner will be of benefit to you. The flues in your chimney were designed for a much hotter and larger volume exhaust stream than what you currently have with your Natural Gas conversion. The cooler and reduced exhaust gasses are excessively cooled while flowing thrugh the chimney, resulting in them condensing into an acidic liquid. This acid eats thru the clay liners, then eats thru the bricks, and can saturate the bricks from the inside. A stainless steel liner is relatively inexpensive, much cheaper than restoring an old chimney!
A 25 year old chimney cap has probably seem better years too.
MI-Roger is offline   Reply With Quote
Old 10-06-2009, 02:10 PM   #9
A common problem that we get with old chimneys in the UK is condensation where the chimney breast meets the ceiling due to hygroscopic salts on the surface of the plaster. This is caused by the burning of fossil fuels giving off these salts which are deposited on the walls of the flue. Water vapour is also created as the fuels give off hydrogen and this condenses at the cooler top of the flue. As the flues before 1965 were usually brick and parged the salts were washed through the walls of the flue and into the plaster. These salts attract condensation at an R/H as low as 50% and can cause really damp patches on the plaster.
These wet spots often confuse the roofers who come back time and time again to replace the flashings, re-point the stack, paint silicone over the bricks etc and none of it works as its condensation. In the end they change their mobile phone number to get rid of the punter.
MI Roger has a good point about the counter flashings(we call them soakers) although I didn't know that roofers were not using them anymore.
As regards whether or not the stack needs rebuilding I couldn't really say for sure without a site visit, but if it is rebuilt and painted make sure a micro porous masonry paint is used as this is said to allow moisture to escape.
Old 10-06-2009, 03:02 PM   #10
1. Call an HVAC company to install metal flues inside the old flues as everything is now gas. 2. Call a brick mason to install counter-flashing in the mortar joints above the top of the roof/tar flashing. Paint as mentioned to allow the moisture to escape from the flue leak inside (though the paint may stop peeling once the new flues and a new cap are installed).
Be safe, Gary
GBR in WA is offline   Reply With Quote
More On This Topic
Roof leaks may not be immediately apparent, which is one of their inherent problems. As a roof leaks, there is the danger that mold and mildew will accumulate. In addition, actual structural damage is also a possibility. That's why it is so important to... Read More »
Being a chimney sweep is a dirty job, but it's certainly something you can make money doing. Starting a chimney sweep business takes a substantial initial investment, but if you do quality work you can recoup that money in no time. Read More »
On behalf of Expert Village I am Nicholas the Storyteller here in Miami, Florida and today I am going to teach you how to tell a story. Do you remember the story of the three little pigs? Most people do but they always say "I have trouble remembering... Read More »
There is nothing quite like a crackling fire in the fireplace on a cold winter day. As wonderful as this may sound, this lovely fire can turn deadly if your chimney is not properly maintained. Every chimney should be cleaned at least once a year to... Read More »
Hi, I'm Bobby on behalf of Expert Village. Everyone loves having a warm fireplace on a cold winter day. The downside to that is you have to clean the fireplace. In this series we are going to tell you how to clean the inside of the fireplace, your... Read More »
Chimney Stucco Repair mikeyboy Building & Construction 7 04-11-2009 12:33 PM
Major Exhaust vent leak - problem? RPM1020 HVAC 7 10-31-2008 01:45 PM
HVAC/Comfortmaker leak problem notsogoodwrench HVAC 8 08-09-2007 10:59 AM
help, Poor performing AC, coolant leak? damaged coil? images maverick06 HVAC 5 07-31-2007 06:30 PM
Possible Fireplace/Chimeny Leak? CharlesMTF Building & Construction 4 10-16-2005 05:49 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
