7/16 "redwood" Panels-any Good? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-13-2011, 11:09 AM   #1
7/16 "redwood" panels-any good?
I'm continuing to try to find options for covering a kid's playhouse, I came across this redwood panel product at home depot. Has anyone used it or have any experience with it? I'm particularly interested in how it will hold up over time. Thanks.
jjjeno is offline   Reply With Quote
Old 04-13-2011, 11:16 AM   #2
i forgot to include the link for the panels
http://www.homedepot.com/Building-Ma...atalogId=10053
Old 04-13-2011, 11:34 AM   #3
kwikfishron's Avatar
Rewards Points: 212
18 bucks a sheet is about as cheap of a siding panel you’re going to find.
BTW there’s nothing redwood about their redwood panel.
kwikfishron is online now   Reply With Quote
Old 04-13-2011, 01:05 PM   #4
anyone know if it holds up over time
Old 04-13-2011, 01:29 PM   #5
Rewards Points: 212
This is the least expensive siding option there is.
The panel is made up of basic of glue and sawdust with a paper thin membrane protecting that.
The key into getting any kind of life out the panel is keeping it “well painted” and damage free. If any water makes it to the core, it’ over. I wouldn’t put it on my home but for an inexpensive siding for a playhouse sure.
If you keep it well painted it should hold up at least as long as the kids will care about playhouses. If this is something you want to have around for a few generations of kids than you might want to spend a few more bucks.
The Following User Says Thank You to kwikfishron For This Useful Post:
jjjeno (04-13-2011)
Old 04-13-2011, 02:18 PM   #6
bigbearz's Avatar
Agreed father in law built the girls a playhouse out at the lake with it... looked good till the next summer and wow.. all bloated out and looked horrible. Might as well of painted OSB probably would have lasted longer.
bigbearz is offline   Reply With Quote
The Following User Says Thank You to bigbearz For This Useful Post:
jjjeno (04-13-2011)
Old 04-13-2011, 02:18 PM   #7
thanks kwikfishron
any thought about this vs. t1-11? that's about $32 a sheet which would be significantly more expensive than the fake redwood composite
Old 04-13-2011, 02:21 PM   #8
thanks bigbearz-just got your response
Old 04-13-2011, 02:51 PM   #9
Rewards Points: 212
Have you looked at this, it wont rot.
http://www.lowes.com/ProductDisplay?...llow&cId=PDIO1
Old 04-13-2011, 03:31 PM   #10
Tizzer's Avatar
Rewards Points: 452
How big will this be, and will it have a roof? Off the ground? T1-11 will be fine if it's not touching earth.
All our storage sheds are sheathed in it, and they've been up for years.
Tizzer is offline   Reply With Quote
Old 04-13-2011, 04:14 PM   #11
I'm now leaning toward the t1-11 even though it's not as cheap. what are the options for finishing it?
Old 04-13-2011, 04:15 PM   #12
it's 6'x8' off the ground with a roof with about a 9" overhang
Old 04-13-2011, 04:19 PM   #13
kwikfishron,
i checked the cement board product link you posted from lowes. is that better than the redwood stuff? how's it compare to t1-11? will it absorb water and puff up like the redwood composite if the exterior is pierced? how do you finish it - paint it? thanks-jjjeno
Old 04-14-2011, 07:05 PM   #14
this shows the value of a community like this. i have now abandoned the idea of ripping 2x4s into siding or trying to use cheap composite or even t1-11. Im now thinking ill use osb covered with vinyl siding.
if i put up osb, how many rains can it withstand before the siding is up? does the siding have to go on immediately or can it wait a while/ I'm not experienced in any of this.I'm learning by doing and that's why all your comments and advice are helpful because I know most of you speak from experience. Thanks-
Are they good Shenandoah Cabinets good quality? robertmazzo Carpentry 76 05-14-2015 10:23 PM
Porter-Cable nail gun kit any good? ajtool Tools 17 08-15-2010 09:56 AM
Where to find good Bifold hardware & doors? smoochas Carpentry 3 07-14-2010 07:28 AM
Roofing Panels Help jackshepard Roofing/Siding 1 06-08-2010 03:55 PM
