6x6 Pergola Post Ontop Of Deck Floor Or From The Ground Up? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-17-2010, 12:42 PM   #1
6x6 pergola post ontop of deck floor or from the ground up?
im building a deck with a pergola on one side of the deck. trying to figure out if i should use the 6x6 post from the ground up or could i just set them ontop of the decking boards. if i bring them from the ground up i would have to notch the 6x6"s out 3 " for the rim joist to sit around them. can anybody give me some advice on this thanks alott
usc529 is offline   Reply With Quote
Old 01-17-2010, 01:52 PM   #2
Rewards Points: 1,016
what's holding up the deck - why not use the 6x6 posts for both decking and overhead pergola?
Old 01-17-2010, 05:45 PM   #3
thats what i want to do but is there a span limit i can run 6x6 post ontop of a deck cause i atleast want them to be 8 ft and how would i secure them to the deck so someone wouldnt lean on it and it shift ?
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 09:39 PM
Are ther alternative to Wooden Post on Deck Foundation herbolaryo Carpentry 2 05-27-2007 08:55 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
deck post question bigjay1151 Building & Construction 4 11-28-2006 08:13 PM
Deck post footings Outbacker Building & Construction 8 02-11-2006 06:20 PM
