6x6 Deck Posts To Concrete Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-13-2009, 12:54 PM   #1
6x6 deck posts to concrete slab
Was wondering if it would be OK to attach a support post to an existing concrete slab using some sort of bracket?
csiryan is offline   Reply With Quote
Old 11-13-2009, 01:18 PM   #2
Yes - simpons makes a support bracket to drill & bolt to the concrete slab
But in most cases you need more support then the slab offers
Here I needed an almost 4' concrete support in the ground
Old 11-13-2009, 01:46 PM   #3
Not so new
12penny's Avatar
Rewards Points: 520
Scubas right. In theory, yes... you can attach it to a slab. In practice, you probably cant because of load issues.
12penny is offline   Reply With Quote
Old 11-13-2009, 02:08 PM   #4
OK Thanks!
Thanks for your replies...I have about a 6" thick slab to work with. I found a bracket at Lowes for the exact application and I think will do. Not the most attractive thing in the world, but will do.
Ryan
Old 11-13-2009, 02:15 PM   #5
Not so new
12penny's Avatar
Rewards Points: 520
csiryan...I dont think you got what we said.
You can attach a 6x6 to anything.
But you cant support a deck with a 6" concrete slab.
At least not here in the northeast.
Old 11-13-2009, 02:20 PM   #6
If you are putting a deck above this you will probably crack the slab if too many people are on the deck & depending upon the size
And if the deck is attached to the house you have to have support to the same frost depth as the house
If you are putting a roof over the slab it maybe OK
Depends upon span & lumber used
Old 11-16-2009, 06:57 AM   #7
OK, I live outside Atlanta.
Why would a slab that thick not be good enough? The only alternative would be to cut the slab out, which would be less than desirable.
Old 11-16-2009, 07:07 AM   #8
Depends what part of the country your from and the codes.
SULTINI is offline   Reply With Quote
Old 11-16-2009, 07:47 AM   #9
Where are you located?...ah you put Atlanta in as location
What are you building...roof or deck ?
Old 11-16-2009, 09:23 AM   #10
Rewards Points: 4,442
depends on how FAR outside of atlanta,,, if you're like me in marietta, probably not a problem,,, if you're 1,500m north of atlanta, problem down here our footers're only 1' below grade since we don't have snowload or frost w/which to contend,,, however, we DO have windload uplift issues,,, good luck !
Old 11-16-2009, 09:28 AM   #11
Household Handyman
Rewards Points: 1,408
csiryan: There are many people on here that offer good advice backed by proper education and experience. Scuba_Davd, and 12penny, happen to be two of them, SULTINI I just don't happen to recognize (sorry). Give more details of your project and listen to them. It does sound as if you are planning a second story deck or roof. Personnally, I do think a 6" slab would hold up a 6x6 post, just not a deck or roof. Good Luck, David
Drylok or epoxy paint for sealing concrete Deck? ohman Painting 7 07-24-2009 04:51 PM
6x6 Cedar post rot stanltod Carpentry 2 06-21-2009 05:54 PM
How to cut a hole in a concrete floor slab tomseeley General DIY Discussions 7 06-10-2009 03:32 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
