-   -   6x6 deck posts to concrete slab (http://www.diychatroom.com/f19/6x6-deck-posts-concrete-slab-57107/)
csiryan 11-13-2009 11:54 AM
Was wondering if it would be OK to attach a support post to an existing concrete slab using some sort of bracket?
Scuba_Dave 11-13-2009 12:18 PM
Yes - simpons makes a support bracket to drill & bolt to the concrete slab
But in most cases you need more support then the slab offers
Here I needed an almost 4' concrete support in the ground
12penny 11-13-2009 12:46 PM
Scubas right. In theory, yes... you can attach it to a slab. In practice, you probably cant because of load issues.
csiryan 11-13-2009 01:08 PM
OK Thanks!
Thanks for your replies...I have about a 6" thick slab to work with. I found a bracket at Lowes for the exact application and I think will do. Not the most attractive thing in the world, but will do.
Ryan
12penny 11-13-2009 01:15 PM
csiryan...I dont think you got what we said.
You can attach a 6x6 to anything.
But you cant support a deck with a 6" concrete slab.
At least not here in the northeast.
Scuba_Dave 11-13-2009 01:20 PM
If you are putting a deck above this you will probably crack the slab if too many people are on the deck & depending upon the size
And if the deck is attached to the house you have to have support to the same frost depth as the house
If you are putting a roof over the slab it maybe OK
Depends upon span & lumber used
csiryan 11-16-2009 05:57 AM
OK, I live outside Atlanta.
Why would a slab that thick not be good enough? The only alternative would be to cut the slab out, which would be less than desirable.
SULTINI 11-16-2009 06:07 AM
Depends what part of the country your from and the codes.
Scuba_Dave 11-16-2009 06:47 AM
Where are you located?...ah you put Atlanta in as location
What are you building...roof or deck ?
stadry 11-16-2009 08:23 AM
depends on how FAR outside of atlanta,,, if you're like me in marietta, probably not a problem,,, if you're 1,500m north of atlanta, problem :yes: down here our footers're only 1' below grade since we don't have snowload or frost w/which to contend,,, however, we DO have windload uplift issues,,, good luck !
Thurman 11-16-2009 08:28 AM
csiryan: There are many people on here that offer good advice backed by proper education and experience. Scuba_Davd, and 12penny, happen to be two of them, SULTINI I just don't happen to recognize (sorry). Give more details of your project and listen to them. It does sound as if you are planning a second story deck or roof. Personnally, I do think a 6" slab would hold up a 6x6 post, just not a deck or roof. Good Luck, David
