5/4" Or 2" Redwood Deck Boards - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-07-2014, 02:31 PM   #1
5/4" or 2" redwood deck boards
I have a deck with 16" OC joists. My friend is telling me that 5/4"x6 boards are too thin and will break unless I have 12" OC joists, but my research seems to indicate that 16" OC is a perfectly fine span. It's going to be a difference of $1,500 for 5/4 vs $2,300 for 2x6.
The 5/4 will be laid 90 degrees from the joists, not on any angles.
Should I just pony up the extra $800 for the 2x boards, or will the 5/4 boards be ok?
scottieslg is offline   Reply With Quote
Old 04-07-2014, 02:49 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,006
Ayuh,.... Yer friend is pretty good at spendin' Yer money,....
5/4 deckin' is the industry standard, at 16" centers,...
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
scottieslg (04-07-2014)
Old 04-07-2014, 03:04 PM   #3
One more quick question...
If I use 5/4x6x12' boards, how far apart should I screw them to the joists?
Old 04-07-2014, 03:55 PM   #4
Rewards Points: 144
It depends on the humidity there at the time you are laying them.In the old days we would just space them with a 16 penny nail and never had any problems.
mako1 is offline   Reply With Quote
Old 04-07-2014, 04:05 PM   #5
Rewards Points: 1,648
I have always just used a standard carpenters pencil as the spacer, using the thinner edge as the space.
And CROWN UP .
ED
de-nagorg is online now   Reply With Quote
Old 04-07-2014, 04:15 PM   #6
Sorry, I phrased that question wrong.
We live in Utah, so it's a pretty dry climate. I'm expecting the boards to shrink, so I'm going to butt them tight and hope that when they shrink, I get a nice 1/8"-1/4" gap.
However, my question was how far apart should the actual screws be lengthwise? Like, should I screw it in one on each end of the board and every 3 joists?
Old 04-07-2014, 04:21 PM   #7
Rewards Points: 144
two screws on every joist and skirt board.
Old 04-07-2014, 04:25 PM   #8
At least.
Old 04-07-2014, 04:31 PM   #9
Rewards Points: 144
You really don't want to put more than 2 because of wood movement.More is not always better.
Old 04-07-2014, 04:37 PM   #10
Rewards Points: 13,446
And do not use galvanized screws!
All I ever use is ceramic coated.
Stainless is nice but about twice the price and it's a soft metal so you'll get some that strip out.
Using an impact driver is the fastest way to drive the screws. A cordless drill is about useless.
Old 04-07-2014, 04:37 PM   #11
You might want to look into a hidden fastener system, It makes the deck look much better.
ED
The Following User Says Thank You to de-nagorg For This Useful Post:
joecaption (04-07-2014)
Old 04-07-2014, 04:48 PM   #12
And rethink those odd ball dimensions.
Most often lumber comes in 8, 10, 12, 14, and 16' lengths.
Old 04-07-2014, 04:57 PM   #13
kwikfishron's Avatar
Rewards Points: 356
What oddball dimensions?
kwikfishron is offline   Reply With Quote
Newb needs Advice on replacing Deck Boards (2x4's, 2x6's) Peacemaker Carpentry 4 08-28-2013 07:20 PM
Dry boards? How far apart should i place my deck boards stofferb Building & Construction 3 07-09-2012 10:05 AM
Stain both sides of deck boards marly Painting 4 07-03-2012 12:18 AM
Underdeck shed , can i roof w/pt plywood & put deck boards to it? BigTy General DIY Discussions 6 05-25-2011 01:45 PM
Cedar Deck boards Outbacker Painting 2 03-04-2006 01:12 PM
