#1 |
4X4 wood posts to concrete for handrail
Need to build a simple handrail for some stairs. It's only 3 concrete steps coming off a porch. There's nothing on either side of the steps. I'm going to use a 4X4 wood posts. My question is how to secure the posts. I initially thought about just burying them in the ground beside the steps in about 2 ft of concrete, but then thought maybe it'd be easier to just attach the posts directly on top of the concrete steps. I know Simpson makes a few different post bases for this, but my question is - Will these post bases provide a strong enough attachment for lateral weight - ie someone leaning against the rail? Thanks.
#2 |
Got a picture?
And your right, just a flush mounted post base will not be strong enough. I just do as you suggested and set the post in concrete next to the steps. |
#3 | |
DIY Enthusiast
4X4 wood posts to concrete for handrailQuote:
Your are correct,they will not be strong enough. |
#4 |
Tool Geek
And ugly too
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. & Stay Safe .....Bob Lavery |
#5 |
Bolt them to the side of the steps. 2x4 will probably be strong enough. That is all I used my two step solid concrete porch and they are solid as a rock.
Do not PM with questions that can be asked in a forum. I will not respond. |
#6 |
journeyman carpenter
get a 4x4 post bracket thats designed for anchoring to concrete. they have a 5/8" hole in the middle for a 1/2" wedge anchor to fasten it down to concrete
| Display Modes | |
| 4x4 posts on top of existing concrete pad | qcliffy | Building & Construction | 7 | 12-26-2009 10:54 PM |
| laminate wood flooring over concrete | janet.giron | Flooring | 3 | 07-28-2009 05:47 PM |
| Do I need to replace a rotten sill plate | met | Carpentry | 8 | 07-11-2008 10:14 AM |
| Framing 2 concrete posts in middle of basement | yummy mummy | Building & Construction | 20 | 01-16-2007 03:14 PM |
| Wood to Concrete without Drilling | MattStata | Carpentry | 1 | 04-19-2006 05:16 PM |
