4x4 Post Bracket - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-19-2010, 04:40 PM   #1
4x4 post bracket
I added a deck onto my house last year and now I want to cover part of it with a metal roofing. I have 4x4 posts that the rails but up against and then there's an extra 5-6 inches for a post cap. I would like to remove the post caps and put another 4x4 post on top now to go up to the roof level. How would I "stack" these 4x4 posts in a way that would secure a metal roof?
I'm thinking if I could find steel bracket that I could put a couple bolts through the bottom post and then a couple through the top post, it would work... but can't seem to find that bracket anywhere. Any ideas?
badfish986 is offline   Reply With Quote
Old 04-19-2010, 04:45 PM   #2
Where are you located ?
How big is the deck ?
Distance between posts ?
Pics ?
Old 04-19-2010, 04:52 PM   #3
I'm in KY. The deck is 24 ft x 12 ft, but I'm only covering a 12 X 12 area. It's 6 ft between post centers.
Picture:
http://lh3.ggpht.com/_Cf4tJujsOyE/S8...2017.49.54.jpg
And this is what I'm trying to do...
http://lh4.ggpht.com/_Cf4tJujsOyE/S8.../s800/goal.png
Old 04-19-2010, 09:46 PM   #4
Registered User
Rewards Points: 5,466
Draw up a plan and run it by your local Building Department.
Be safe, Gary
Old 04-19-2010, 10:03 PM   #5
One way is to notch each 4x4 & bolt them together
I'm not sure how that will work with a railing
Do the existing posts go all the way down to concrete piers ?
Old 04-19-2010, 10:46 PM   #6
Is this what you are thinking about?
BC4Z
I have to assume these wouldn't be considered sound for a post to post connection. They are intended for a post to beam connection. I've used them for connecting scrap 4X4's as horizontal "runners" under a movable turkey pen with no problem.
On the cheap you could you put in a half lap splice and reinforce with double bolts. I can't say if that would be structurally sound either though. I'm just a jury riggin' farmer that likes to save money and experiment. Of course it's no fun experimentin' with a metal roof flying through the air like a guillotine (especially when there's turkeys involved)...
dc loud is offline   Reply With Quote
Old 04-20-2010, 08:06 PM   #7
If at all possible, I would install new posts, rather than try to splice the existing ones!
In my area, a building permit would be required for this job and splicing wouldn't be allowed by our code!
Considering the wind and snow loads that you contend with, you should be very careful to build safely!
Deck Post Height for Composite Post Railing ylwdog Building & Construction 5 11-15-2010 09:01 AM
Post mounted electrical receptacle NIlRO Electrical 13 04-19-2010 02:20 PM
