42" Deck Rail Height Required In N.C.? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-03-2012, 02:12 PM   #1
DIY Homeowner
Rewards Points: 79
42" deck rail height required in N.C.?
The last time I built a deck, the code in North Carolina was 36" minimum height for deck rail (a.k.a. guard). Just took a look at the 2009 IBC with 2012 N.C. amendments and Section 1013 on Guards says 42" minimum height.
Did N.C. up it from 36 to 42 inches? I hope not. I just built an extension to my deck with the same guard rail height as the old section, 38 inches.
BRO931 is offline   Reply With Quote
Old 10-03-2012, 02:56 PM   #2
42" deck rail
I sure hope that NC regs didn't change the height on railings or I'm going to be in the same boat as you are since I made all of my 36" off of the deck floor. I'm also located in NC.
snrubr is offline   Reply With Quote
Old 10-03-2012, 03:05 PM   #3
http://ecodes.biz/ecodes_support/fre...C_Res_2012.pdf
Pianolady is offline   Reply With Quote
Old 10-03-2012, 03:56 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,052
locally handrails must be a minimum of 36" when the landing or deck is below 6' high. onces its at or above 6' it now has to be 42"
woodworkbykirk is offline   Reply With Quote
Old 10-03-2012, 04:44 PM   #5
DIY Homeowner
Rewards Points: 79
Originally Posted by Pianolady View Post
Thanks Pianolady. I forgot to check the residential code in addition to the building code. Never could figure why they are not one in the same.
Drip edge / rail solution for flat concrete deck jjnero Roofing/Siding 1 07-19-2012 05:02 PM
Hand rail height mclemenc Carpentry 8 02-10-2011 08:16 PM
Deck Staining thread but I am desperate- please help mickbiv Painting 3 09-08-2010 01:28 AM
Any suggestions on rail for a Timbertech XLM deck? jcims Building & Construction 0 09-07-2010 01:46 PM
Rail Rake Height... Melanie337 Carpentry 28 12-26-2009 10:22 AM
