4 5/16" Door Jamb Width - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-20-2011, 03:54 AM   #1
4 5/16" door jamb width
My house was built using 3/8" drywall, both inside and as sheathing. The rough opening appears to be able to accommodate a standard pre-hung door, which I've already purchased on sale. The problem is that standard jamb widths are 4 9/16". The door jamb will have roughly a 1/4" to 5/16" overhang once installed into the rough opening.
I've thought about it a lot. The best solution I can think of is to remove the brick molding from the pre-hung unit and route a recess on the backside, and then reinstall it so it not only covers up the overhang, but also sits flush against the house.
Also, since it's only the brick molding I'll be modifying, I'll get out relatively cheap if I screw it up. I can buy more brick molding.
What do you think? Does anyone else have any ideas or experience with this?
jleentvaar is offline   Reply With Quote
Old 09-20-2011, 06:12 AM   #2
DIY staff
Rewards Points: 7,174
Your Idea should work well---you have to be creative sometimes.
This will make adding a screen door difficult,however, so adding a 'trim extender ' might be better.
a strip if 1/4" stock glued or pinned to the back outside edge might be better---
Old 09-20-2011, 06:18 AM   #3
Thanks! I thought about that as well. I don't know if they make 1/4" trim extender as such. I would, however like to stay away from soft wood. This particular door is in the kitchen leading to the covered patio in the back.
Old 09-20-2011, 07:52 AM   #4
Framing Contractor
Rewards Points: 118
Remove the door from the jamb and run the jamb carefully through a table saw.
sixeightten is offline   Reply With Quote
Old 09-20-2011, 09:11 AM   #5
Rewards Points: 150
How about you just go to a real lumber yard and order the right jamb size to start with. Probably cost you less at a lumber yard than a box store anyway.
TrapperL is offline   Reply With Quote
Old 09-20-2011, 01:07 PM   #6
Thumbs down
Oh really? Wow. I didn't know that custom made pre-hung doors were so cost effective. I paid $128 for this door at Lowe's. I'd rather make minor modifications than spend well over $300 on a custom door for a 1/4" difference.
Old 09-20-2011, 01:38 PM   #7
Rewards Points: 29
This makes most scents
spinfisher is offline   Reply With Quote
Tags
brick moldings , exterior door , jamb , rough opening
where to find narrow plank width laminate pamelajosmith Flooring 2 03-13-2011 11:58 PM
New Private Construction Minimum ADA garage width ? Snowheels Building & Construction 4 06-22-2010 11:33 AM
Anyone know where to find a 5/16" x 5/16" V Notched Trowel? fjlcisco21 Flooring 5 08-12-2009 04:58 PM
Does return duct width matter? bvbellomo HVAC 13 01-11-2009 02:03 PM
Question about stairwell width jonblack Building & Construction 40 09-22-2008 09:48 AM
