Old 11-16-2005, 04:35 PM   #1
Default 35 year ago foam insulation
Have rental house with that gosh awful asbestoes slate siding. 35 years or so ago somebody drilled like 1" holes thru outside and shot house walls full of the foam insulation. Remodeling the bath recently the foam was a pile of dust in the bottom of the stud cavity or turned to it fast enough. Was looking to reside it but need to replace windows first and insulate. What do I do with the existing foam all over the rest of the hoiuse? Blow celulose thru existing holes till cavity is full again?? Then is vinyl siding the best for a rental for toughness or is what they call cement board siding the way to go?? If you have to paint that, how often?? Cant paint the way I used to. Does that fall apart like that wide masonite board siding does?? Thanks for any help!! --d--
justdon is offline   Reply With Quote
More On This Topic
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. I want to talk to you for a minute about these arched windows like this. Okay we've put... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. In talking about insulation, one area that we need to cover is how well your house is sealed... Read More »
Cellulose insulation is an eco-friendly form of home insulation that's made from plant fibers. Like the more common fiberglass insulation, it can be inserted between walls and into roofs to keep homes warm during the winter and cool in the summer. Unlike... Read More »
Hi I’m Amelia and this is an insulation blower and I am about to load it with some cellulose insulation. Cellulose is a loose film type of insulation. It is often used in attics and other places. The nice thing about it is it is a lot healthier... Read More »
So the next step to insulating an existing wall is to patch the hole that has now been filled with expandable insulation with drywall compound and you will want to apply this with a putty knife. You want something fairly wide. You want it to be at 1... Read More »
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Building & Construction 13 08-03-2007 09:48 PM
Spray in foam insulation leted_82 Building & Construction 3 05-31-2007 12:14 PM
Rigid foam as floor insulation rkhpapa Building & Construction 3 09-24-2006 08:06 PM
Foam board insulation martin gager Building & Construction 0 07-04-2004 03:50 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
