-   -   33' span (http://www.diychatroom.com/f19/33-span-108045/)
fwjoe 06-18-2011 05:57 PM
33' span
My wife and I want a covered patio addition. 37' x 13' with load bearing posts at 33' and 12' from house. don't care if beam is steel or wood, contractor says it can't be done, I find that hard to believe.
concretemasonry 06-18-2011 06:11 PM
How does your wife want to support the roof from the house and where? - I am assuming you want to attach one end to the house somewhere (roof wall or ledger).
How will the outer support be actually supported (patio slab or separate footing?
In many places, it can be impossible based on your specified criteria and local conditions like wind, snow and codes. For information will give you better answers. Geographic information is necessary.
These type of additions come under very close scrutiny by any code offical ar futures buyers inspect since that could be constued of being a wat through the back door to add on room (#101 in the code reviewers manual).
Sorry to be so brief, but without more information, it is just a guess and your "contractor" may be right or just doesn't want the liability.
Dick
Joe Carola 06-18-2011 06:27 PM
Ask an architect or engineer. They are the only ones who can design something like that.
fwjoe 06-19-2011 08:11 AM
(on top of ledger)
(footing encased in patio)
(fort worth texas, minimal snow, only wind)
thanks for the replies
Daniel Holzman 06-19-2011 09:27 AM
I have no idea why the contractor "said it can't be done". If the contractor is experienced, they would not have said that for structural reasons, there are plenty of potential beam types that would work structurally. Whether the lot geometry prohibits the addition (zoning rules), I have no idea. You may want to hire an architect to design the addition, they will spec the required beams, check code requirements, and apply for the permit. They can also assist you in bidding the job, and finding a contractor to actually do the work.
