31 Ft Beams - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-19-2017, 09:32 PM   #1
31 ft beams
Today I finished removing an existing 26 ft exposed bean held up with 3 columns in my living room. I replaced the double 2x12 exposed beam beam with 2- 31 ft 18" 1-3/4 laminated beams and hung the joist with joust hangers.
I noticed when we were putting the up one of the beams was starting to determinate at come points on the bottom. It was in couple of places. The longest was about 1 ft and encompassed just one or 2 layers. Since the beams were 32 ft long we had to cut off 8" ft from each. We used one of the 8" pieces as a support nailed flat to the wall to sit the beam on as we raised it. When we went to pull it off the wall with a claw hammer it broke in half at the highest nail. It was nailed with the grain horizontal. Im wondering if they are that weak bending against the grain?
larrylwill12 is offline   Reply With Quote
Old 05-20-2017, 05:12 AM   #2
Rewards Points: 1,660
Re: 31 ft beams
Having a bit of trouble understanding this part:
"I noticed when we were putting the up one of the beams was starting to determinate at come points on the bottom. It was in couple of places. The longest was about 1 ft and encompassed just one or 2 layers."
The determinate in blue above, might delaminate have been what was desired in wording?
bob22 is online now   Reply With Quote
Old 05-20-2017, 09:48 AM   #3
Re: 31 ft beams
"I noticed when we were putting up one of the beams it was starting to determinate at some points on the bottom. It was in couple of places. The longest was about 1 ft and encompassed just one or 2 layers."
Hey man it was late and I was beat was up since 7am working on it.
Your right delaminate, spell checker got me again. Its not in thunderbird. There were a couple of ather mistakes also I corrected.
Would pictures help?
Old 05-20-2017, 11:42 AM   #4
Rewards Points: 680
Re: 31 ft beams
Pictures always help
BIG Johnson is offline   Reply With Quote
Old 05-20-2017, 12:55 PM   #5
Re: 31 ft beams
here are some pictures
31 ft beams-6.jpg   31 ft beams-5.jpg   31 ft beams-4.jpg   31 ft beams-2.jpg   31 ft beams-1.jpg
Old 05-20-2017, 04:56 PM   #6
Rewards Points: 680
Re: 31 ft beams
That's totally normal.
Is it spanning 31' unsupported?
Old 05-20-2017, 05:02 PM   #7
jlhaslip's Avatar
Rewards Points: 2,748
Re: 31 ft beams
Agreed that these look pretty normal. Is there a chance that these LVL have been stored outside for a winter?
Usually they are covered and don't show issues unless they have been subject to weather.
Do you have a picture of the "stamp" on the LVL which may include a build date.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 05-20-2017, 05:49 PM   #8
Re: 31 ft beams
Build date is 3/24/17
They were cleaner but we brought them in before building the supporting walls and tearing the old one out, so a lot of debris got on them.
The room is 30ft wall to wall. We cut them to 30'8" Had to slide one end into the hall door which was about 9" from the final placement. Upped one end, slid it into the ceiling cavity then upped the other and pulled it back into place. There are 2 - 18" x 1/34 x 30'8" 4 Jack studs under each end. Also a pony beam I had to build on top to the roof and side supports every 6' No support other than the side walls.
Old 05-20-2017, 06:17 PM   #9
Rewards Points: 680
Re: 31 ft beams
Why aren't the lvls touching? I was trained that they need to be tight together with proper nailing to get full loading capability. For a window header no big deal but for a 30' span I'd want it right. 30' unsupported is a long way. Did you pull a string and check sag? I'd bet it's considerable. I'm going to guess over a 1/2". I could be wrong. But I doubt it.
When I do 18' garage headers I jack up the centers unloaded to manufacture a slight crown until all lvls and wall sheating is nailed. Then I remove the jack.
Old 05-20-2017, 07:08 PM   #10
Re: 31 ft beams
The engineer figured out for 3 16 inch lvls I asked if I could do 18" He said they were way more than enough. It was impossible to get the together due to having to cut the rafters wider than 3.5" get them in from an angle of 9-10"
This house was built in 1964 its a one story rancher. The living room was originally 10 x 30, then someone added a porch 10 x 30 with a concrete floor then someone enclosed the porch making the LR 20 x 30. 1/2 wood floor , 1/2 concrete. Really no way to get closer than 1/4 " due to the concrete slab. One side of the LR measured from the top of the beam is 114.25 the middle 114 and the other side 114. The trusses were joined with an overlap in the middle on top of the old beam and the original beam was 2 12 x 28 about 1" apart but held up with 3 columns. Some rafters are higher than others and some twisted. Its an old house. I straightened what I could and pushed up what I could and pulled down what I could. Its definitely better than what it was.
Elevated Platform & Playhouse - More beams or more posts? eko Building & Construction 17 09-15-2015 11:10 AM
Need suggestions on repairing rotted pergola beams shaftmaster Carpentry 5 04-27-2015 02:33 PM
Gazebo Beams and Joists and Posts power_tree Building & Construction 0 09-07-2013 06:55 PM
Stacking beams jklingel Building & Construction 32 12-16-2012 01:37 PM
PT beams warp or twist off posts? windowguy Building & Construction 5 09-06-2012 07:24 AM
