3 Season Porch Foundation On Sand - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-14-2013, 11:05 AM   #1
Rewards Points: 14
3 Season Porch Foundation on Sand
Hi, we recently purchased a small lake house in Wisconsin and wish to remove the old deck and replace it with a 3 season porch. We are looking for advice on the best type of foundation as we sit on 20-30 feet of sand. I am fearful that pillars would eventually sink into the sand. Any advice on the type of foundation and depth would be appreciated.
Also...we have an exposed stairway leading to the basement. I would like to incorporate an enclosure for the stairway with the construction of the 3 season room. Any ideas on the best way to accomplish this as well?
RickDJ is offline   Reply With Quote
Old 10-14-2013, 11:20 AM   #2
Rewards Points: 3,130
What sort of foundation does the house have?
Old 10-14-2013, 11:22 AM   #3
Rewards Points: 14
The basement is block walls, so would "assume" a poured foundation below the block.
Old 10-14-2013, 12:01 PM   #4
Civil Engineer
Rewards Points: 4,520
Your local building inspector probably knows exactly what type of foundation is suitable and acceptable. Sand is typically a very good material for foundations, you are not going to get any settlement as long as the sand is properly compacted prior to placing the footings for the porch. Depth required is typically to frost, which could be four feet in WI. Again, check with your building inspector, but you can probably use strip footings effectively, or sonotubes at appropriate spacing.
Tags
foundation , porch , sand
Need help with how to mount porch light to concrete foundation wall wherm5150 Electrical 7 11-16-2010 09:56 PM
3 Season Porch Remodel Biyobe Remodeling 8 04-10-2010 08:27 PM
How do I renovate my 3 season porch? glamgirrl Remodeling 4 03-09-2010 08:34 PM
Pouring a porch up against the house pws Building & Construction 5 09-25-2008 07:52 PM
Pollen season and my new yellow porch dchaban Building & Construction 9 04-25-2008 01:18 PM
