3" Drain Vent Pipe Going Thru Shed Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 02:31 PM   #1
Rewards Points: 1,062
3" drain vent pipe going thru shed roof
my 3" drain vent pipe is going through the roof of my shed. was wondering:
1. what should i use to insulate the edges/trims of the circle opening to prevent water from dripping through? i am also concurrently building a deck and am acquiring some Vycor tape for ledger flashing insulation, was wondering if i can apply some of that?
2. what kind of cap should i get to go on top of the pipe to prevent stuff from falling in (like the stuff that people through out of flying objects, LOL) ?
Old 02-08-2011, 02:50 PM   #2
rditz's Avatar
go to home depot (other other similar store) and get a gasket for the pipe. I presume that this is the black ABS pipe. they make a rubber seal that slides on over the pipe and is installed when you are shingling. if it truly a vent, then no cap needed.
rditz is offline   Reply With Quote
Correct Way to Flash a Vent Pipe With Metal Roof? jonathan03 Roofing/Siding 4 06-22-2010 03:57 PM
Max length for a drain pipe w/o vent Bcoleman6 Plumbing 8 05-06-2008 09:11 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
