3/4"x8" Cedar Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-01-2012, 11:56 AM   #1
3/4"x8" cedar siding
My plan is to use horizontal rough cut white cedar for siding, I'm thinking of using 3/4"x8" boards with a 2" overlap, leaving an obvious 6" exposure. The mill tells me they can saw the boards square or with a bevel, 3/4" -> 1/4". I'm worried about the air space behind the boards, anyone ever installed like this before?
vtboy51 is offline   Reply With Quote
Old 03-01-2012, 07:46 PM   #2
kwikfishron's Avatar
Rewards Points: 368
You defiantly want the lap siding milled beveled so the siding will lay flat.
There’s nothing to worry about the air space behind the siding. In fact code in many places now are requiring an air space (rain screen) between the siding and the weather resistant barrier.
kwikfishron is offline   Reply With Quote
Old 03-01-2012, 07:54 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,114
kwik is right, having a air space behind most types of siding is mandatory in most regions. it allows for air flow behind hte siding which allows the siding and the wall to dry thus reducing rot and possible leaks
woodworkbykirk is offline   Reply With Quote
Prep, repair cedar siding before restaining Clicchi Painting 0 09-10-2011 05:03 PM
Cedar Siding Alternatives for Small Reveal jburr827 Building & Construction 2 05-17-2011 07:02 AM
Asphalt shingle siding over cedar shakes Catguy Building & Construction 1 04-05-2010 09:10 PM
Vinyl siding over cedar siding dbldee20 Remodeling 8 02-21-2009 07:06 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
