3/4" T&G Plywood Over 1/2" Subfloor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-12-2009, 06:10 PM   #1
3/4" T&G plywood over 1/2" subfloor
I have removed the 3/4" particle board subflooring that was installed over
1/2" plywood subflooring. I am going to replace it with 3/4" T&G plywood.
My question concerns the nailing of the 3/4" plywood. Do I fasten it or not fasten it to the floor joist ? I have seen different opinions. I will be using 3/4" strip flooring as the finished floor.
Stude is offline   Reply With Quote
Old 12-12-2009, 08:19 PM   #2
Civil Engineer
Rewards Points: 4,580
I too have been curious about the different opinions on proper installation. From review of manufacturers posted information, I conclude that the underlayment (the lower plywood layer) should be nailed or screwed to the joists using ring shank nails or screws approximately 1 1/2 inches long. Most of the sites I checked state that you should NOT glue the underlayment down, although I am not clear why not.
Most of the sites recommend attaching the second layer of plywood (the upper layer) using nails or screws slightly shorter than the thickness of the plywood, to prevent penetration through the lower layer, that could damage pipes or wiring. They also do not recommend gluing down the upper layer, and they do not recommend nailing into the joists. Presumably the lower layer is already firmly attached, hence there is no need to overkill the project by nailing or screwing the upper layer into a joist.
Old 12-12-2009, 08:49 PM   #3
Framing Contractor
Originally Posted by Stude View Post
I
You HAVE to nail it to the floor joists. Start at the opposite end so that the joints don't line up. You don't need T&G for the underlayment above a 1/2" subfloor..
Joe Carola
Joe Carola is offline   Reply With Quote
Old 12-12-2009, 09:05 PM   #4
Rewards Points: 163
On quick question. Why do you have a 1/2" subfloor. I have never seen or heard of that.
paul100 is offline   Reply With Quote
Old 12-12-2009, 09:39 PM   #5
Framing Contractor
I started framing in 1983 all we used was 1/2" subfloor and after that we would go back and install 1/2" underlayment. We stared using 3/4" T&G around 1987.
Joe Carola
Old 12-12-2009, 10:18 PM   #6
Registered User
Rewards Points: 5,266
http://www.apa-europe.org/Languages/.../PDF/R340G.pdf
Be safe, Gary
Old 12-13-2009, 01:10 AM   #7
Registered User
Daniel, the glue can show through on some resilient flooring products due to the dark color and chemical make-up of the glue----- even 1/4" plywood. With hardwood flooring over, glue is good from APA: http://www.apawood.org/searchResults...ent=srv_search
Free membership, Form R 280.
Be safe, Gary
Old 12-14-2009, 01:50 PM   #8
Isn't there a way you can add to the 1/2" you have? It seems like taking it out is going to be a really big job with a lot of potential downsides.
pyper is offline   Reply With Quote
Old 12-17-2009, 04:59 PM   #9
Registered User
Be safe, Gary
Old 12-17-2009, 05:19 PM   #10
Newbie Bill
Rewards Points: 520
I think the OP was stating he was going to replace the 3/4" particle board with 3/4" T&G. He will be leaving the existing 1/2" subfloor.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 12-18-2009, 10:39 AM   #11
ccarlisle's Avatar
That's what I read, too. It almost sounds like he's about to tile the floor and If so, then replacing the particle board with T&G plywood is essential.
Plus, if he's tiling, he shouldn't screw the T&G into the joists. So since we don't know what he's going to do (tile, hardwood, VCT etc), none of us is in a real good position to say what to do with the subfloor nor the underlayment.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 12-18-2009, 10:46 AM   #12
Too many pronouns.
When he said "1/2" plywood subflooring. I am going to replace it " I thought he was talking about replacing the plywood.
Old 12-18-2009, 11:38 AM   #13
Newbie Bill
Rewards Points: 520
Further to this, the OP indicated he/she will be laying down 3/4" strip flooring.
Bill
Old 12-18-2009, 01:08 PM   #14
ccarlisle's Avatar
My bad...missed the part obout strip flooring.
Old 12-26-2009, 03:38 AM   #15
I would nail, no glue. Nails should go into joists when possible and be used every 10-12 inches on face of the plywood whether its t7g or not. need to leave expansion room at all edges. reason for the nailing is so that you don't have "creeks" when you walk on it when its finished. I used no t7g plywood under finished product and nailed 4 in in from edges then 6 inched in through the whole sheet. Trick is to nail it down good and tight, no squeaks or creeks later! nails are the flat head with the swirls along the shaft so they don't wiggle out easily for the non t&g plywood. However, with t&g, the common nail could be used so it doesn't split the tongue part. Good luck, I had a lot of help from this site putting in my flooring I'm looking for drywall info this morning though
brenda o is offline   Reply With Quote
how to fasten plywood to subfloor to even out floor height cmlcsu Flooring 11 11-08-2009 10:19 PM
Subfloor repair Dave321 Flooring 3 09-16-2009 09:59 PM
Expand/Contract: Glue & screw 7" x 3/4" OSB strips on top of 3/4 plywood subfloor ? iMisspell General DIY Discussions 8 05-11-2009 08:09 PM
Plywood underlay to subfloor - size screw? ygeorgiay Flooring 3 08-01-2008 12:36 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
