3/4" Osb Or 3/4" Plywood For New Sub Floor? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-17-2011, 04:35 AM   #1
Question
3/4" osb or 3/4" plywood for new sub floor?
what are the pros and cons of 3/4 " osb vs plywood for new sub floor?
and if I go osb how long can it be exposed to the weather while I get the walls up and roof, can it get rained on or will that ruin it?
treerat is offline   Reply With Quote
Old 03-17-2011, 06:32 AM   #2
I am old school so my view are different from younger guys. I prefer plywood. It can get damp(neither likes WET/soaked) longer than OSB, and IMHO is stronger. Plywood is more expensive. Both are OK with most building codes, OSB is the construction preference because of cost.
Old 03-17-2011, 06:33 AM   #3
Rewards Points: 150
Everything depends on the weather, how complex and time consuming the house is, and quality of help you have, and how soon you can get it under roof. OSB or plywood are good products, but I'd go with plywood if you have a crawl space over dirt, with moisture conditions, and use glue , squeaks are hell.
bernieb is offline   Reply With Quote
Old 03-17-2011, 08:20 AM   #4
Hey Treerat,
I have experience with how OSB and plywood will react over time outdoors. OSB will eventually get ruined. It absorbs water, swells up, and start to crumble into pieces. Regular plywood is a little bit better. It doesn't absorb as much water, it will still swell, and it will warp, but wont fall apart as easily. I would definitely go with regular 3/4" plywood. What are you doing exactly?-Gregg
gotogregg is offline   Reply With Quote
Old 03-17-2011, 08:27 AM   #5
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Neither one of those are a good choice at all because you stated that moisture and rain will be a factor.
Advantech ....period!!!!!
tcleve4911 is offline   Reply With Quote
The Following User Says Thank You to tcleve4911 For This Useful Post:
DexterII (03-17-2011)
Old 03-17-2011, 08:43 AM   #6
Rewards Points: 120
Yup, Advantech.
Old 03-17-2011, 08:43 AM   #7
kwikfishron's Avatar
Rewards Points: 762
Whichever you choose don’t build your floor and then the walls in a couple of months and the roof months after that. I’d get everything together and not start until you can at least get it all dried in.
kwikfishron is online now   Reply With Quote
Old 03-17-2011, 11:39 AM   #8
this is a bathroom REBUILD! foundation up, one person show. probabably take me about 3 weeks, but its spring and I can expect rain every other day, just wanted to know if osb would survive that amount of time and getting soaked every few days? would a tarp help much?
Old 03-17-2011, 12:11 PM   #9
Rewards Points: 762
You should be fine, just make sure you have a sufficient tarp to cover it all and focus on the roof and siding before messing with the inside.
Old 03-17-2011, 03:39 PM   #10
Remodeler
JCarsten's Avatar
Adventech is one of many brands out there for subflooring. Most T&G (tongue&groove) plywood that are worth anything is coated with some type of water resistant coating. They can get wet, but clear off the water everyday and you shouldn't have an issue. A tarp certainly can't hurt.
JCarsten is offline   Reply With Quote
Old 03-17-2011, 03:58 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Advantech would be my material of choice. We work with it a lot around here. Advantech will survive some weather and delays if you don't abuse the privilege. Be ready to keep moving once the product begins. Advantech is treated somewhat but if it gets too wet too many times the panels will edge-swell a little. Even that isn't the end of the world. The swelled edges can be sanded if they are a problem for some reason.
You'll be fine if it is only a three week project but get it in-the-dry ASAP.
XXX
Old 03-17-2011, 04:04 PM   #12
Remodeler
JCarsten's Avatar
Here's a link to Durastrand flooring- OSB, not plywood.
http://www.ainsworthengineered.com/a...oors/flooring/
I have used them in the past with good results.
Most likely not available at big box places- check with local builder supply (ABC, ProBuild, etc).
Old 03-17-2011, 04:17 PM   #13
Rewards Points: 762
And how much a sheet on Adavntech. Never seen it out here.
Old 03-17-2011, 04:27 PM   #14
Registered User
Rewards Points: 526
Regular OSB will edge swell= irreversible. Use plywood or an "enhanced product" pp. 2: http://www.utextension.utk.edu/publi...files/W176.pdf
I drill holes in the shallow puddles soon as they form on a large house deck, if no plastic in crawl yet. Use a tarp (remodels I tie it to house tails, use ropes and pulleys for a giant Roman shade), cover the wood from the sun, etc.
Gary
Old 03-17-2011, 06:39 PM   #15
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Haven't a clue.
I just know that my builders that use Advantech compared to my builders that use OSB from the box stores cause me a whole lot fewer headaches when it comes to prepping a substrate for a tile installation.
It's hard to compare one new home to another because of the variables in weather exposure and time of year during construction but hands down Advantech performs better than the other products.
That's not to say I don't have any edge-swell to deal with because I do. It is the degree of edge-swell that seems to be a lot less with Advantech.
XXX
Floor is out 3/4" zetti1102 Flooring 11 09-26-2010 09:31 AM
Hardwood floor questions (56K) ukrainetz Flooring 1 08-02-2009 01:08 PM
Movement in bathroom floor rob_di_mostly_y Kitchen & Bath Remodeling 2 07-24-2009 03:37 PM
floor leveling, plywood subfloor in a bathroom bloom42 Flooring 2 02-05-2009 06:55 PM
Remove 3/4" oak floor before cement board and ceramic tile goes down?? 4just1don Flooring 8 10-31-2008 10:32 AM
