3 Or 3.5" Screws To Install Fence Panels? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-01-2012, 01:39 PM   #1
3 or 3.5" screws to install fence panels?
3" or 3.5" wood/deck screws to install pre-fab fence panel?
Will be going into mostly 4x4 PT posts but also some 6x6. Face nailing (screwing) directly onto posts.
Everywhere I've read says 3" screws would be fine but it looks as if about only .75" is going to actually in the PT post holding the fence panel. Wondering if that will be enough to hold these panels up over time.
Fence panel is 6'x8'
snosurfa7 is offline   Reply With Quote
Old 07-01-2012, 05:14 PM   #2
Rewards Points: 2,202
if only 3/4" is going in i'd go with the 3.5" screws
mae-ling is offline   Reply With Quote
Old 07-03-2012, 09:43 PM   #3
Easy rule, 2/3s of the faster should be driven into the sub straight.
RYANINMICHIGAN is offline   Reply With Quote
Aluminum fence panel section temporary removal BrandonC_1972 Landscaping & Lawn Care 3 05-08-2012 10:03 PM
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 11:50 AM
shadowbox fence Joe028 Building & Construction 2 05-12-2010 09:40 PM
Largest Crown Molding Cut on DeWalt 716 Klawman Carpentry 8 11-14-2009 09:05 PM
Fence Bid - A Rip-Off ??? kenziekiss Building & Construction 7 12-31-2006 08:12 PM
