3 1/2 Framing Nails - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-10-2009, 01:01 AM   #1
3 1/2 framing nails
i've got my 3 1/2 framing nails and they are 3 mm thick.my question is are they thick enough for framing the walls .advice me please!
moja is offline   Reply With Quote
Old 05-10-2009, 08:47 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
Moja, yes the nails are thick enough for framing but why did you get them so long, 3 inches would have been plenty long for regular framing.
BigJim is offline   Reply With Quote
Old 05-10-2009, 09:58 PM   #3
(the original)
Rewards Points: 756
jiju1943, moja is in a seismic zone in Romania. moja, you probably should have posted in your previous thread just to avoid any confusion California uses 3 1/2" x .162", which I believe is closer to 4mm. Not very many guns will handle that nail, though. Bostitch has one, I'm not sure of the model #. Have you looked into hold downs and tie plates yet? Reinforcement of your connections is just as important, if not more so, than nail size.
ratherbefishin' is offline   Reply With Quote
Old 05-10-2009, 10:58 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
I am sorry, I didn't know where he lived. I am use to the code in Tennessee. I guess I should have asked first. Thanks for letting me know.
Jim
Old 05-11-2009, 03:06 PM   #5
Rewards Points: 1,910
If I converted right the 3mm nails are 0.118" thick. That diameter might be suitable for attaching sheathing but is a little small for framing lumber. Since they are 3 1/2" long you might still be able to use it but you'll need to use more nails at each connection.
In your other post you mentioned you were going to use 6/2 timber. I don't know what size that is. Did you mean what we call 2x6 in the US (which actually is 1 1/2 by 5 1/2 inches)? Let us know the dimensions of the lumber you are using. In the meanwhile I'll look for a nailing schedule.
Old 05-11-2009, 03:17 PM   #6
Here is a nailing schedule that is accepted in most areas of the U.S. You should be able to use the seismic information to figure out a nailing schedule for your project in Romania.
http://www.icc-es.org/reports/pdf_fi...e=ESR-1539.pdf
framing nails moja Carpentry 12 05-03-2009 10:53 AM
Can I use ring shank nails for framing? bluefitness Building & Construction 3 12-18-2008 09:17 PM
Size/Type of Nails for Interior Framing? mfleming Building & Construction 2 09-16-2008 08:39 PM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 10:31 PM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
