2x6 Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-25-2012, 10:22 AM   #1
2x6 wall
How much weight will a 24 foot wall made of 2x6's on 16 inch centers hold
chris hummel is offline   Reply With Quote
Old 08-25-2012, 10:24 AM   #2
Rewards Points: 13,446
Why? What is it your really trying to do?
Old 08-25-2012, 10:34 AM   #3
wall
I have a 24ft by 24ft addition next to my garage. I want to split it into two rooms, 12ft wide and install a ceiling to create a loft for storage. My ceiling beams will be 2x6 on 24 inch centers which will rest on the wall. 5/8's plywood will go on top of the ceiling for the loft floor. I was going to build a 24ft wall from 2x6's with a 3 wide 2x6 header. In addition 4x6 posts will be built into the wall on 8 foot centers. Am I over building?
Old 08-25-2012, 10:41 AM   #4
Framing Contractor
You can build that out of a 2x4 wall.
Joe Carola
Joe Carola is offline   Reply With Quote
The Following User Says Thank You to Joe Carola For This Useful Post:
chris hummel (08-25-2012)
Old 08-25-2012, 11:21 AM   #5
GBrackins's Avatar
Rewards Points: 2,108
If I understand your post correctly you are talking about building a wall to divide the space. what is the purpose of the 4x6 posts?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 08-25-2012, 11:48 AM   #6
Framing Contractor
I have a 24ft by 24ft addition next to my garage. I want to split it into two rooms, 12ft wide and install a ceiling to create a loft for storage.?
You will have to support that wall underneath.
Joe Carola
Removing a portion of a load bearing wall WFCC Carpentry 3 09-17-2011 06:17 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
