A 2x6 To Span 21' As A Ceiling Joist??? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-28-2009, 09:26 PM   #1
A 2x6 to span 21' as a ceiling joist???
Someone suggested this on another forum
Every span calc I've seen I'd be lucky to be able to use a 2x10 to span 21' ???
http://www.terrylove.com/forums/showthread.php?t=27018
Old 02-28-2009, 11:08 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,344
The AWC specs that as a 2x8 12 on center for an L/180. 2x10 for SPF #2, however.
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 03-01-2009, 01:58 PM   #3
Rewards Points: 5,336
A 2x6 ceiling joist for that length is not correct if this was just a garage with no load on top.
You don't mention what's on top, but if the span needs to be that long I would look into engineered beams.
Ron
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 10:57 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Ceiling Joist Worries clayrabbit Building & Construction 11 01-06-2008 05:07 PM
Ceiling Joist Beam Construction? Stargazer Building & Construction 1 08-26-2007 10:50 PM
ceiling joist this old house Building & Construction 2 03-23-2006 09:00 AM
