2x6 Lumber To A Cement Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-16-2010, 08:06 AM   #1
2x6 lumber to a cement slab
how do I attach 2x6 to excisting cement slab to apply 3/4' plywood on top .
hookiedo is offline   Reply With Quote
Old 07-16-2010, 08:23 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I would use pressure-treated lumber only directly on concrete, and nail to slab with nail gun (concrete nails).
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-16-2010, 02:56 PM   #3
Registered User
Rewards Points: 526
Is this for a finish floor in a basement? Did you test for moisture? http://www.buildingscience.com/docum...ms?full_view=1
Don't forget the sill sealer under it for a capillary and thermal break. P.t. wood is not waterproof: http://www.greenbuildingadvisor.com/...-building-code
http://www.thompsonswaterseal.com/advice/faq.cfm
Be safe, Gary
Old 07-16-2010, 03:00 PM   #4
Civil Engineer
Rewards Points: 4,854
Options include Phillips red heads (needs a rotary drill), 22 or 38 Ramset (rent the gun), concrete nails (very poor attachment), expansion anchors (install using a drill with masonry bit). As noted, lumber must be PT. I assume lumber is being installed flat face down, if you are attaching through the 5-1/4 inch side that is a different problem, let us know if you need to install the long way.
Putting a gas line in cement slab wskiarea Remodeling 2 03-26-2010 06:59 PM
Cement slab touches buildings cbuisman Building & Construction 2 06-09-2009 10:24 PM
xps and t&g on cement slab? HABSFAN2006 Flooring 10 04-14-2009 07:28 PM
upright posts in a wet cement slab shellgirl74 Building & Construction 7 03-19-2009 11:06 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
