2x6 Ledger W/ 2x8 Joists? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-22-2011, 11:52 AM   #1
Rewards Points: 358
2x6 ledger w/ 2x8 joists?
I am replacing the deck at my parents house and they currently have deck 14' wide by 7' deep constructed from 2x6 joists at 16" o.c.. They want to extend it to 18' wide and 10' deep. I plan on using 2x8 joists @ 12" o.c., but my question is can I keep the 2X6 ledger, attach it appropriately with lags and then use top flange hangers to hang the joists off of it? The only reason I ask this is because the 2X6 is perfectly flashed and it would not require me to cut or remove any siding.
No permit/inspection , but I would like it to be totally safe and meet code. I know 2x6 joists to not meet IRC but I did not see any notes about ledges.
cbzdel is offline   Reply With Quote
Old 07-22-2011, 12:00 PM   #2
AGWhitehouse's Avatar
Doesn't sound like an issue to me providing you use the top flange hangers.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 07-22-2011, 12:25 PM   #3
Rewards Points: 358
i just check the simpson catalog, and there are only (2) top flange hangers with 1-1/2" top flanges, the JB which provides ZERO uplift and the LB which provides 290lbs uplift, I am not sure if only 290lb uplift is adequate. I wanted to cantiliver the deck joists over the support beam, but with only 290 uplift, I dont think that is a good idea..
Any input?
Old 07-22-2011, 12:44 PM   #4
general rule of thumb is 2'-0" cantilever needs 8'-0" of deck. So a 2'-0" cantilever needs a minimum of a 10'-0" deck. I wouldn't rely on a joist hanger to hold the deck down from a huge cantilever.
Old 07-22-2011, 02:29 PM   #5
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Help me understand, if the existing ledger is flashed so well wouldn't you be compromising it by installing top-flange hangers?
Andy.
AndyGump is offline   Reply With Quote
Old 07-22-2011, 02:57 PM   #6
Registered User
Rewards Points: 526
You are looking in the wrong Code book: http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
That one says..... I'll let you be surprised!
Gary
Old 07-22-2011, 03:05 PM   #7
Rewards Points: 358
that one says 2x6 still not allowed and looks like the ledger has to be the same size as the joists..
Gotcha!
This one is flashed very well and the siding is cut perfectly around the ledger. I would have to remove the old ledger because it got pretty beat up removing all the nails in it so my plan was to install all the hangers prior to installing the ledger to the house. That WAS my plan, not sure if it was a good one or not haha
Old 07-22-2011, 03:39 PM   #8
Registered User
Rewards Points: 526
From page #9; 7. “Residential Decks not exceeding 200 square-feet (18.58 m2) in area that are not more than 30 inches (762 mm) above grade at any point and do not serve a required exit door.” http://www.govme.org/download/PDF/Co...deAdoption.pdf
Gary
Old 07-22-2011, 05:04 PM   #9
Framing Contractor
Why not?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 07-22-2011, 06:30 PM   #10
If it were me and i was doing it i would do the whole thing right and not worry about it , and get permits too so just in case the inspecter does swing by one day
fulton 22175 is offline   Reply With Quote
garage loft; ledger to ledger joists? nsixbdg Building & Construction 10 12-26-2011 06:29 PM
Bubba's been here. Repairing sagging rim/floor joists. MattFels Building & Construction 7 02-09-2011 05:28 PM
Install Flashing onto existing deck ledger, stucco home Ameekins Building & Construction 1 09-15-2010 05:51 PM
question about joists and ledger mikeluvs2build Building & Construction 4 02-13-2010 01:43 PM
attaching joists to ledger for pergola question soupdizzle Building & Construction 1 07-02-2008 10:32 PM
